Mods: iceman cold air. dc sports ceramic header, venom 400 control module, b+m regulator and pressure gauge, advanced timing, port matched intake and exhaust ports, ported and polished gsr manifold, clutchmasters aluminum flywheel and stage 3 clutch,
what injectors swap into a gsr-michael delaney?
what injectors and what size are they. i have seen rc engineering injectors listed as for eclipses and honda products . same part # is this possible because i heard that the eclipse injectors for turbo are pretty big. what size are they. can we get a list of possible injector parts swaps so we can save a little money
getting type r cams and 100 shot dp nitrouseven though they may not be needed now i plan on a turbo in the future with some internal engine changes. will the eclipse injectors fit without any modifications other than the resistor packs and where can i get these.
Originally posted by Daremo 450 would be way too much fuel ....... you'll run way too rich off of the nitrous.
sorry about the mixup i was editing my post while you were writing yours. thanks for the info. i just really want a cheap alternative in the 270 to three hundred cc size range. i also was thinking homebuilt turbo kit and my friend has the eclipse injectors that he used before switching to 750s. thank you
speaking about injectors, what should I use for jrsc integra, 310cc or more or less? What happen if you run too rich...and what about too lean? (I guess I just want the best for my car)
