Hi i have integra 95 LS automatic and i want to put a manual because i want to put some boost into it....what is the best transmission i should get????? GsR?? B16? please help
try asking in the turbo section or do a search, theres tons of threads of people asking that question. i hear a LS tranny is good for boost cause of the longer gears so u can stay in boost longer. The gsr tranny has shorter gears which give better accerlation but ur not in boost as long. Also the LS tranny is way cheaper than the GSR tranny. good luck with your venture.
Mods: Exterior:JDM headlights, VISION corners, JDM tail lights, Carbon Fiber front lip, Carbon Fiber hood, carbon fiber VISION side mirrors, gold 16 x 7 ADVAN Racing RG wheels, Carbon Fiber duckbill wing Interior: Stock blue interior converted to black
i thought the ITR tranny was good? i heard it gave good acceleration over the LS tranny.
Oh hell no, you'd have no traction... you might stop spinning your tires after you've shifted into 4th....
ITR/CTR/B16A Trannies are good for nautrally aspirated cars, turbo cars have far too much power to put it to the ground.
Imagine it like this, it's like riding your 21 speed bike with the chain on the smallest sprocket on the front and the biggest one on the back in a race.
'96 Integra Turbo @ 15psi built by me in my garage.
heheheheheheh thnx for your reply..but i'm a total noob...
what is " LS w/ GS-R 4th and 5th. 4th and 5th are too long for the 1320. " what do you mena by 4th and 5th ??? sorry..
Originally posted by nolovenodie heheheheheheh thnx for your reply..but i'm a total noob...
I think he meant a LS tranny with the GSR 4th and 5th gears timing/gearing ratio and how it won't matter about the 4th and 5th because you don't use the 4th and 5th in 1/4 racing.
Jason
What I ment
You'll go thru just to 3rd if the car is mostly stock. The 1320 is the quarter mile, just measured in feet. Cars with a little more power, go into 4th gear in the 1/4 mile. Personally, I finish the 1/4 at 8000rpm in 4th gear. My friends' race cars finish midway thru 5th gear, closer to the top (depending on which tranny), but they run 9's.
The LS 4th and 5th gears are too long.... once you shift into 4th it bogs.... that's why if you have the GS-R 4th and 5th, it will be better for a higher-performance 1/4 mile car, but if you're driving on the highway a lot, it would be best to stick with the LS 5th gear.
