Old 10-28-2006, 10:56 PM   #1 (permalink)
5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future
Antec 900 Gaming Case - Review
Ok so rarely do people post reviews here but I figured I would 'cause... well 'cause dammit.
Firstly I purchased this case in a fit of rage tonight. It cost me $169 after taxes at Best Buy. You can easily get it for around $140 shipped if you search.
In the box is a set of 3 120mm 3 speed fans. The front two have blue LED's. The real kicker is the 200mm 3 speed fan on the top. With the other fans disconnected this thing moves enough air to cool the case. I had an existing Aspire 120mm blue led fan from my XQPack (which by the way sucks the big one) that i slapped on the side. So i'm up to 4 120mm's and 1 200mm. Damn skippy.
When at full speed the case is annoyingly loud. It is not as loud as other cases I've had but it sits on top of my desk so it's a pain. However the benefit is that my components stay very cool. Even with stock cooling on my P4 3.06 (Yeah yeah it's ancient) I never go above 40*C. Compare that to my Aspire XQPack which regularly saw 55*C and then would cause the system to crash. Also because of the 120mm on the side the video card will now reach no higher than 55*C (X850XT AGP) when it would regularly see 75*C and then crash the system.
The case, just like any other antec case, is a joy to work in. Everything is well placed and just works. The fan positioning is great, they create strong air flow from the bottom front to top back. The PSU is housed at the bottom of the case which is different but seems to work well.
Another bonus of this case is that it has 6 spots for 3.5 inch hard drives. All of these hdd bays are behind the two front 120mm fans so they recieve ample cooling. There are two problems with the front HDD/Optical Drive bays. Firstly they sit way to close to the motherboard I have installed in this case. All IDE/SATA cables have to be folded and ziptied to achieve anything other than a rats nest. Secondly the hdd bays slide out from the front so you are required to take both sides off and remove 8 screws for each set of 3. (Honestly at this point I'm just bitching)
The build is antec's usual steel and plastic. When the sides of the case are removed they are flimsy, however they become strong as they are attached to the case. The mesh on the window side of the case could be attached a little better as it uses some hot glue to attach in certain key places.
All in all I would give this case a solid 9 out of 10. The only thing that could make it better would be frontal placement of the USB/Audio ports, more room length wise (1/2 to 1 inch) and better attachment of the mesh on the side.
Pics in a second.
That's a DVD sitting on top of the 200mm fan for size comparison. It's friggin huge. There's nothing else to describe it.
Shift_wheelhop
5gencivic is offline
Old 10-28-2006, 11:12 PM   #2 (permalink)
Also just to clarify I purchased this because my XQPack decided it was time to regularly start shorting out the system. I would get approximately 2 minutes of run time at normal temps and then it would just go dead. I don't think I'll be buying another case any time soon but when I do it'll be another Antec. I'm sold on the quality.
Shift_wheelhop
Old 10-29-2006, 02:04 AM   #3 (permalink)
SuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problem
Nice rig! That case looks so nice in the picture, but when I saw it in person it looked . I agree antec case have very good built quality. All that money and new screwless drive mount? After using a screwless case, I would never go back to a screw mount drive case. Not that I take my drives out everyday or anything like that.
Give me about a month or two I will most up the review on my new rig. Its going to be riced out like hell.
SuperAkuma is offline
Old 10-29-2006, 03:06 AM   #4 (permalink)
gurusan's Avatar
Nice...I've been wanting to buy this for a little while now but it's not super high on my priority list.
Is it possible to get some pics of the clearance between the GPU and front of the case?
The only thing I don't like about it is that it seems like it will be very hard to tuck away PSU wires.
uɐsnɹnƃgurusan
Teal Civic Sold: 08/31/2006
FOLD FOR SHO! TEAM 54075
folding@home
gurusan is offline
Old 10-29-2006, 04:35 AM   #5 (permalink)
Dark Samurai
Squirrel's Avatar
Car: 1986 Mazda Rx7, 2004 Nissan Xterra SE
Mods: 5-lug swap
Squirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapy
i want that case soo bad!
Squirrel is offline
Old 10-29-2006, 09:06 AM   #6 (permalink)
I'll post some more interior pics of the case a little later today. I'm headed out for food right now.
The PSU wires have absolutely no where to go. It's not like earlier antec cases where the cables had a location to hide in the top and then snake out of. With this case they're just there. I have a small rats nest going on but it honestly doesn't bother me. With 4 - 120mm's and 1 - 200mm there's just so much air flow it's sick.
If that 200mm ever breaks tho I'm sure it's going to be a $30 or more fix.
Shift_wheelhop
Old 10-29-2006, 10:03 AM   #7 (permalink)
Rev ATARI's Avatar
Mods: Ending Corporate SHO Member #1
Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?
Personally I don’t like the case, I think it’s poorly designed and looks cheap. They are over compensating fans for poor airflow issues, so noise is going to be an issue. The PSU should be up top so the heat from it does not travel from the bottom all the way up to the top passing all the internals. The top where the 200mm fan looks second rate in terms of fit and finish and then there is the cabling issues.
PPL
Rev ATARI is offline
Old 10-29-2006, 11:44 AM   #8 (permalink)
Hey you can't please all the people all the time. It's not loud but it's not quiet by any means. I still like it.
Shift_wheelhop
Old 10-29-2006, 08:24 PM   #9 (permalink)
Rev ATARI's Avatar
Oh I understand you can please em all, I’m just saying I don’t see the hype
PPL
Old 10-30-2006, 10:40 AM   #10 (permalink)
Manniefresh0586's Avatar
Car: 92 civic
Mods: Fully Built B16, F2 Coilovers, DC Sports Header, Skunk2 Manifold, Skunk2 Throttle Body, Skunk2 Camgears, and the list goes on.....
Manniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapyManniefresh0586 needs rep therapy
i like tha case espically the two fans in the front.
Bakwudz Racing
Manniefresh0586 is offline
Old 10-30-2006, 03:18 PM   #11 (permalink)
I guess I must have missed out on the hype. Unless you're talking about hype that I've created. In wich case I point to the fact that I was stoked as hell about my pc looking good and operating well. Wich I'm still stoked about so I don't care.
Here are the requested pics of the Video to front drive cages section. The bottom drive cages aren't a problem because there's nothing remotely near them but the top drive cages are close to an AGP video card. PCI Express people or SLI/Crossfire people should be ok as long as the PCI Express slots are moved down a bit.
Shift_wheelhop
Old 10-30-2006, 04:23 PM   #12 (permalink)
STOCK CPU HEATSINK!
Old 10-30-2006, 05:07 PM   #13 (permalink)
Originally Posted by SuperAkuma
STOCK CPU HEATSINK!
Not for long.
Shift_wheelhop
Old 10-31-2006, 08:32 AM   #14 (permalink)
Iron Monk
fartbomber's Avatar
fartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratuspherefartbomber In the stratusphere
Case fans will be loud and you can't do anything about it unless you go to water cooling.
I always put my PC below my desk. I started doing that when I had a PC and a Solaris workstation on top. It was very noisy, both fans and hard drives. Just putting it physically below the desk decreased sound by a lot. I don't see the big need to have the PC case on top of the desk.
Glowing LEDs inside the case is pointless.
fartbomber is offline
Old 10-31-2006, 10:24 AM   #15 (permalink)
Lifeless Ninja
AlSi's Avatar
Car: 2009 Honda NSX (my time machine is great)
AlSi has a Rep problemAlSi has a Rep problemAlSi has a Rep problemAlSi has a Rep problemAlSi has a Rep problemAlSi has a Rep problemAlSi has a Rep problem
