Ok first, are you using Win9x? Usually if your computer contains an IDE hard disk that is 8 gigabytes (GB) in size or larger, the Performance tab in System properties may show that the hard disk is using MS-DOS Compatibility mode. MS-DOS Compatibility mode may be in use for either the file system or for virtual memory.
