Well I had my block done up by laskey racing. I'm happy with the internals that were chosen. Here's a quick list:
Benson sleeved block
Benson balanced and micropolished crank
Custom Pistons and rings 9:1
Pauter rods
ACL bearings
OEM (TypeR) oil pump
Lower gasket set
Blueprint and assembly
I'm told by Mike Laskey that they can make up to 1000 WHP. Were you planning on assembling your block yourself? If not Laskey is good because they blueprint it for you. This means they build it tighter then manufacturer specs.
For my head i went with
SuperTech Stainless Steel nitride coated valves
dual valve springs
titanium retainers
I've also heard great things about Ferrera valvetrains.
I skipped out on the port&polish to save some money since I could meet my goals of 500WHP on stock portwork.
I just got my head back 2 days ago and will be slapping it together on the weekend.
You might want to consider downgrading that turbo to a GT30R. Mike@synapse is making I think 575WHP with port&polish on a GT30R. GT30R is better suited for your engine and drivetrain. The step from the GT30R to GT35R will cost you more money on drivetrain parts. With the GT30R I'm able to use a competetion Stage 5 Sprung Clutch. However if I wanted to run a GT35R I'd have to add an additional pressure plate, plus your diff/axles is at a greater risk of breaking. I mean if your desire is to be making 600+ WHP GT35 all the way but I think the GT30R is much better suited if it can deliver you to your horsepower goals. I was originally building for the GT35 but recently changed my mind to the GT30r. Mike@Synapse swapped out his 35 for a 30 and is happy with the new turbo.
For Injectors I ordered precision 1000 cc. I'm running a ctr intake cam and a gsr exhaust cam. People have made great power on the stock cams.
A note on the bore size I notice alot of people go 84mm but check what Mike Laskey has to say about bore sizes:
First off, all sleeves are made of nodular iron, as it is the only material that is compatible with breaking in (seating) rings. Therefore, all sleeves have virtually the same physical strength. (The real differences in sleeved blocks are who does the install, how good does the installer holds his machined tolerances and what is the installing procedure). Taking that fact into account, bore size in any sleeved block is limited to the center line of the stock bores in the block and how much meat is left BETWEEN the cylinders. I always tell my average customer (using his motor on the street) to do no more than 83 mm on a turbo application and 85 mm all motor. Obviously these numbers can be increased and the motor will live but the question is for how long and how many rebores are left in the block. We are testing an 86mm turbo block with the thought that the block must live and survive in a racing environment. I would assume that same block would go 87 in all motor and be able to live also. This block uses Prelude sleeves but of course is still limited by bore centerlines.
I believe claims of an 87+mm are probably true. The question becomes how long did the block survive and did the extra bore make more power or cause a power loss because of the sleeves distorting from being too thin and actually cause compression loss?
Benson is also working on offset sleeve project that changes the centerline of the cylinders. This can increase potential bore size available. The first tests will be in an all motor configuration.
I know I didn't give you a definite conclusion on bore size because I don't think there has been enough real testing by ANYONE. Any company that will tell you that their sleeves are good for X amount of boost or Y amount of bore, is really just blowing smoke. It is all based on the thickness between the sleeves. The reason I preach 83mm for turbo blocks is that it allows room for several rebuilds before you will need to sell your block to your all motor buddy. Tuning errors and part failures can cause the need for a fresh bore from time to time. For those that say I can make more power at 84mm bore rather than 83, I say just turn up the boost an extra pound on your 83mm and enjoy the power.
I took his advice and went with 83MM for my first build. Well good luck with the project and I hope my post helps a bit.
