I decided imma go for this, does anyone know where i could pick up some new a6 pistons?? Also how about the bottom end? does anyone even make crank's for the D series? if not what's the strongest crank to use from the stock D series motors??
I am planning to use a y8 head with my y7block. I have a friend that can port and polish the head and intake manifold (i figure use the manifold from a y8) for me. Throw in an aftermarket cam. (what company has an agressive cam that would also work decent enough for street use?? I was thinking a Gude looked best??). Also i would just use an OBD1 ecu from an ex. Then just bolt on's from there. I figure the most expensive thing to buy and install will be the cam so it shouldn't be all that hard. Anyways any opinions/corrections would be greatly appreciated.
I would post this in the all motor thread but it seems to be dead
edit*- i know you cant' put B series pistons or heads into/onto any d series motor but could you use the rods or crank??
Damnit mods move me to civic-tech...wrong window my bad ...lol
