DPFI to MPFI HELP!!!
ok so i did my DPFI to MPFI swap today i wired everything up correctly and checked it about 5 times... when i tried to go start the car it would just crank and not start at all... my ecu is throwing code 4 but ive already rechecked my crank sensor about 10 times already and it still wouldnt start and still throwing code 4... iam stuck till this point because i dont know what to do any more... ive cut C1 & C2 and wired them to B10 & B12 and then from the empty C1 & C2 slots i wired my crank sensor up to that... i checked it over and over and over and also tried starting it everytime i checked it but still no start... can anyone help me out... also i think that my wiring for the injector might be wrong because iam confused about the wiring there... the yellow wire from the dx injector to #1 injector (brown) and red wire from dx inctor to #3 injector (blue)... cant i just connect that straight to the ecu instead of doing that?
