Ok...my engine swap is really pissing me off now
Ive got a ITR motor in a del sol , which used to have a b16a (SIR 2 motor).
My installer has used my existing wiring harness (from my b16a) while using the plugs & harness from the ITR (motor side). On the ecu side im still using my b16a ECU (OBD1).
It was ok for a couple of days but when i go over 7500 rpm for ecxtended periods (6secconds+) i get the engine check light comming on...and the car goes in limp mode. It ONLY happens in vtec ie above 5800.......about 70% of the time...
Im running a vafc...but im enriching it at some points +18 and its still running 14.1 (lean) once Vtec engages...i cant seem to fix that lean spike and im wondering if its my vafc which is causing the ECU to trip?...i dunnno.
I know i should run the proper ECU...but the wiring is a complicated since none of the honda dealers are willing to provide me with the schematics for the ITR (DC2, 96 model). Where can i get these off the net?
Has anyone done a ITR conversion on a B16a (OBD1) and used their existing wiring harness ??..if so were there any complications trying to rewire these into an OBD2 ITR ECU??? (apart from time) AND are there any additional sensors on the ITR motor which wouldnt be 'taken into account' when using the b16a wiring harness into a b16a ECU?
Sorry for the long post but its really bothering me especially since the engine checklight gets tripped sporadically.
cheers
demonic_sol
PS: this is a double posting..srry bout that but would like feed back from all thnks
