Eng swap ECU code 8
Just completed installing D15b vtec in 89 civic si.. tried re-wiring dizzy from d15 and when key is on and trying to engage starter (nothing) ecu throws code 8. Re-wired orginal dizzy and had the same results .. When turning key "nothing" starter does not turn,, battery has been on charger for 8 hours , and we can cross the selonoid on the starter and turn it over, but nothing when turning the key except the code 8 on the ECU..
? any ideas before I drag out the vom.. !
