first off, how is gear oil related to brake fluid??? i don't get it. if you dont know where to put your brake fluid maybee you should ckeck the owners manual. as far as mixing them, it's fine as long as you dont mix DOT 5 w/ anything accept DOT 5. and yes, everycar with a maula tranny has gear oil. check your manual as to what type it takes also. if you need help changing the gear oil do a SEARCH. you will find it.
Steve
