Mods: Exterior Lighting, Kicker 7" In Dash DVD, Yellow Engine Dress Up Kit, 18" ADR's W/ Cooper Tires, Blue Interior Lighting, Megan Headers (DO NOT BUY), Side Marker, Turn Signals and Corner Lights
H22 Engine Swap
When you swap an Accord F22 Engine with an H22, can i use the accords axles on the h22??? If not what do i have to do?
Mods: Type-S Swap. Neuspeed/AGX suspension, AEM CAI, APEX'i dunk catback, DC Sports front strut/rear sway, APEX'i V-AFC. Alpine head, 2 polk 10" DVC's, 2 Hifonics amps, Infinty kappa's all around.
As long as they're in good shape, go ahead and use them. The h-sereis engines are bolt up swaps, you can even use the F-series tranny if you want to, although it won't deliver the same results as the H-tranny would.
Mods: Nothin much yet...17x7 Tenzo Shu-4 knock-offs w/ Falken tires, RActive exhaust, 20% Tint, Full Custom Stereo, fully dented up exterior waiting for work
Yeah, the axles can be used with either engine. It is recommended to swap them out if the miles are fairly high. Modified did a couple articles on swapping the H22 into a 94 + Accord, including recommended and necessary parts as well as the actual swap process itself. I can put up the article if you need...GL on the swap
