i don't know which engines come in which trim verisons (LX, DX, etc)
what kind of engine will you be re-using the parts from? what kind of engine do you have now?
if you don't know, pop the hood and look at the headers, then look a few inches left and a few inches down. there is a little metal tab. it may be dirty, so get a rag and scrub the grime off. there will be a series of numbers and letters engraved. as soon as you find out which engine you have and which engine you had , we can answwer your questions better.
it will probably be something close to D15B7 orB16A2.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
