how to check if water pump is working. - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 09-26-2005, 11:36 AM   #1 (permalink)
Car: 1992 Honda Prelude
Mods: h23vtec, exhaust, headers, intake,Koyo aluminum radiator,Aem Pulleys,auto to manual conversion,Koni yellow suspension with vspec coilovers, energy suspension bushings, rsx blaze orange paint, 17" Konig Tantrum Wheels, Full Combat body kit. Custom molded side skirts.
92h23vtec is on a distinguished road
Does anyone know how to check if your water pump is working? I have a prelude and I haven't gotten a clue if I need a new water pump or not.
92h23vtec is offline
Old 09-26-2005, 03:04 PM   #2 (permalink)
Car: 98 Civic HX
dapimp has a spectacular aura aboutdapimp has a spectacular aura aboutdapimp has a spectacular aura about
If your car runs normally and doesn't overheat your water pump is in working order. If you have over 100k miles on your pump I'd suggest you change it to be safe.
dapimp is offline
Old 09-27-2005, 09:31 AM   #3 (permalink)
550whp is on a distinguished road
Take the radiator cap off. Start the car let it warm up so the thermostat opens up once it does you should be able to see the coolant circulating in there. If it's not then either the thermo is bad or the water pump is bad.
550whp is offline
Old 09-27-2005, 10:19 AM   #4 (permalink)
thanks to all that posted
Old 09-28-2005, 03:23 PM   #5 (permalink)
cupcake_224 is an unknown quantity at this point
only change the pump if it is already leaking. the pump shows signs of wear in it starts to leak a bit. and if you don't overheat your ok, the pump works fine.
cupcake_224 is offline
Old 10-03-2005, 07:06 PM   #6 (permalink)
MATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problemMATTXR250R has a Rep problem
Another way to check is get the engine warmed up to operation temp. Then pop the hood and grab the upper radiator hose...pinch it shut..if you can feel pressure like it wanting to expand then the water pump is working. If you change Water Pump be sure and change your Timing Belt,Cam seals and front main seal as well. No reason in tearing it all apart and not do that. Doesn't make sense.
MATTXR250R is offline
Old 10-05-2005, 02:31 PM   #7 (permalink)
HondaVTEC93's Avatar
Car: 2006 Honda Civic Ex
HondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problem
if ur timing isnt fucked up and ur not overheating
HondaVTEC93 is offline
Old 11-02-2005, 09:08 AM   #8 (permalink)
GunMetal Member
Car: 1991 Acura Integra GS Sedan
G2IntegraGS will become famous soon enoughG2IntegraGS will become famous soon enough
How does it affect timing? My car has been pinging under some high load situations and it has also been over heating. Could this be caused by my water pump?
G2IntegraGS is offline
Old 11-02-2005, 10:34 AM   #9 (permalink)
timing belt
