Old 12-02-2002, 12:52 AM   #1 (permalink)
Car: 1994 del sol dohc vtec
Mods: pro-1 CAI, TAnabe exhaust, 10.3mm obx plug wires, ect..muchmore
byrdcharlie is an unknown quantity at this point
how do i adjust my cam gears?
i need to know how to adjust my cam gears, i just got them put on and the shop put them on the stock settings. They said to advance them about 2 0r 3% untill i got my turbo put on then to retard them. And they kept the intructions for my fpr so how do i set it. they set it up alittle he said but when i asked for details they just said to play with em' till i find what i like.... :
byrdcharlie is offline
Old 12-02-2002, 01:07 AM   #2 (permalink)
Car: 1999 Honda S2000
Mods: Straightened exhausts, larger air filter, fuel controller. Port and polish and possible turbo later
Sunder is an unknown quantity at this point
Dump that two cent business and take it to a real tuner.
Someone who says "Play with 'em till you find what you like" is asking for their customers to blow an engine (Possibly so they can sell them a new one)
You mess around with Cam gears too much, and you might be seeing your piston get intimate with your valves. And let me tell you, it ain't a romantic picture.
MY99 S2000
13.9 @ 99mph
When the clutch drops, the BS stops.
Sunder is offline
Old 12-02-2002, 01:18 AM   #3 (permalink)
lol thanks. should i even try advancing them alittle or not? what should i set them on?
Old 12-02-2002, 01:40 AM   #4 (permalink)
Usually within +- 3 degrees is safe. +- 10 degrees is extremely dangerous (because of valve contact - IE valve hasn't closed by the time the piston is near TDC so they collide.
But.... Advancing it doesn't always gain you power. Sometimes retarding it will. The power you gain is usually so subtle, you need a dyno to feel it - because it might only wipe 0.1 of a second off your 1/4 time.
Leave it neutral until you get it to a tuner.
MY99 S2000
13.9 @ 99mph
Sunder is offline
Old 12-02-2002, 11:51 PM   #5 (permalink)
thanks alot for the help on that. i guess i will leave em'. Whatta bout my fuel pressure regulator now though?. i forgot how to set it and they kept my instructions damn it....
Old 12-03-2002, 12:17 AM   #6 (permalink)
An FPR usually has a screw that will let you turn up and down the pressure. Clearly, the higher the pressure, the richer it'll run
Tuning an FPR is a touch easier than tuning Cam gears, but once again, the best results come from running on a dyno.
If you can get your hands on a AFR meter, generally you want to tune towards mid 13s for a naturally aspirated engine. Don't let it get too close to 14.7, otherwise you'll start hearing detonation. If you hear detonation, make sure you richen it up a bit quickly.
If you have G-tech, and a long straight road to do some runs, you may be able to get a good feel for what works best in your car using that. If not, once again, dyno is best.
MY99 S2000
13.9 @ 99mph
Sunder is offline
Old 12-03-2002, 12:24 AM   #7 (permalink)
pr0_re is an unknown quantity at this point
no afense man but you need to stop going to a shop and start doing tthis stuff your self. its not as hard(for me at least) then people make it out to be and its alot of fun to have a couple guys come over to do car S.
pr0_re is offline
Old 12-03-2002, 12:47 AM   #8 (permalink)
nahhh thats ok no offense taken but i've put alot of money into my car and im not gonna jsut start fucking around with the shit that i dont wanna have to get fixed because me and some buddies messed with it. BUT i do know how to do most of this shit. mostly on other ppls cars. i dunno why but when it comes to my own car i'd rather have a professional do it i guess... but i am going to adjust the fpr and stuff.
i just couldnt remember how the hell to do it.. thanks sunder...
Old 12-03-2002, 12:57 AM   #9 (permalink)
I would say do most of it yourself. Fit the cam gears and cams yourself, fit the FPR yourself, go for it. No problem.
But don't tune by yourself. Unless you're one lucky bastard to own a dyno, you're only going to get mediocre results using a "Butt Dyno" or even a G-tech. A dyno can tell you when you gain 1/2 a HP. Can a G-tech?
MY99 S2000
13.9 @ 99mph
Sunder is offline
