» Sponsors
» Sponsors
Old 04-27-2003, 11:53 AM   #1 (permalink)
Rev ATARI's Avatar
Mods: Ending Corporate SHO Member #1
Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?
How Do I Perform A Compression Test?
I think this has been posted before, but oh well. It's quite simple and there are a few ways to do it that might differ a bit from what i describe. So your best option would be to get a Haynes, or some kind of name brand repair manual, that will have step by step instructions.
First of all you need the "compression tester" tool, that you can find at any auto parts stores for around $30. Don't pay more for the most expensive ones, its not necessary. Then you need to find out the factory compression specs for your paticular motor, optimal (standard) and the minimum allowed before rebuild. Lastly your motor needs to be at operating temperature and have a good battery as you will be cranking the motor a bit.
Basically what a compression check will tell you is what mechanical condition the upper end, ie pistions rings, valves, head gaskets are in. More specifically if there is leakage from the piston rings, defective valves and seats or a blown head gasket.
1. Begin by cleaning up a bit around your spark plugs to prevent crap from falling down into your cylinders when you take the plugs out. Dirt getting into your motor is not a good thing.
2. Many manuals will tell you to take out all your spark plugs all at once but I believe this is unnecessary and increases your chances of mismatching your plugs when you're finished. But what ever you wanna do or find easier.
3. Block the throttle wide open, which i didnt do just floor the gas pedal when cranking.
4. Disable the fuel system by removing the fuel pump fuse, and disable the ignition system by detaching the primary low voltage wires from the ignition coil. Or like me and just disconnect the coil spark wire from the coil, your call on this one.
5. Install your compression gauge on which ever cylinder your heart desires, I started on number 4 and worked my way to number 1. The guage installs very easy just like a spark plug except you dont tighten it down more than hand tight.
6. Crank the motor over several times, I cranked for about 4 seconds per test and watch the guage climb. In a healthy motor, compression should build up rather quickly. Low compression reading on the first stroke, followed by very gradually increasing compression on successive strokes, indicated work pistion rings. A low compression reading on the first stroke, which doesnt build up during successive strokes, indicated leaking valves or a blown head gasket, which also could be a cracked head. Heavy carbon deposits on the valves could also cause lower than average reading as well as a possibly higher than average reading. Record the highest reading that the guage stops at after cranking for a bit.
7. Repeat this process on the remaining cylinders
8. If the readings are much below normal (standard) readings, try and add some oil, about a teaspoon's worth, directly in the the spark plug hole and repeat the test.
9. If the compression increases significantly after the oil is added, the pistion rings are definitely worn. If the compression doesn't increase significantly, the leakage is occuring at the valves or a head gasket leak is to blame.
10. If two adjacent cylinders have equally low compression, theres a strong possibility the head gasket between them is blown. The appearance of coolant in the combustion chambers or the crankcase would verify this condition.
11. If one cylinder is about 20 percent lower than the others, and the engine has a slightly rough idle, a worn exhaust lobe on the camshaft could be the cause.
12. If the compression is unusally high, the combustion chambers are probably coated with carbon deposits. If thats the case the cylinder heads can be removed and decarbonized. Or my way to fix that if it's not too severe is use some bad ass fuel system cleaner and drive that ish the way it was ment to be driven, that usually cleans out the majority of the bad carbon.
13. If compression is way down or varies greatly between cylinders, it would be a good idea to have a leak-down test performed by a automotive repair shop. This test can pin-point exactly where the leakage is occuring and how severe it is.
14. Lastly reattach everything the way you found it.
Good luck and if it matters at all, the compression specs for my 92' accord are: Standard 178psi and Minimum 135psi
Which I found 175/174psi over all 4 cylinders, dont ask me why it was so consistent, I guess it had some thing to do with the old people that owned my car before me that changed the oil every 2000 miles and never drove over 70 mph Last note, I am not resposible for any mishaps or if your car explodes or what ever the case maybe.
By asdrg
Every time you post on SHO, Jesus rapes a child
Rev ATARI is offline
Old 01-04-2004, 10:58 AM   #2 (permalink)
bruinteg has a spectacular aura aboutbruinteg has a spectacular aura about
Reverend ATARI, what do you think of this compression test on a 94 GSR with 100kmiles : 180-175-175-175
Now you mentioned that carbon deposits can cause lower than average readings or higher than average readings - interesting I thought by reading other places that carbon deposits will cause only higher than average readings. Anyways, the gauge went up pretty fast with each successive crank with all four cylinders - can I conclude that bad piston rings or blown headgasket are not to blame?
bruinteg is offline
Old 03-18-2004, 01:45 AM   #3 (permalink)
Car: 97 Acura Integra LS
Mods: AEM CAI, DC CC 4-1 Header, Tanabe Super Racing Medallion cat-back, Skunk2 Short Shifter, Shift Knob, Lower Tie Bar, Upper Front Strut Bar, Rear Strut Bar
RabiDIntegrA is an unknown quantity at this point
do you hand crank it or do you turn the ignition?
95 Honda Civic CX 98 B18C ITR
05 Yamaha R6
97 Acura Integra LS: SOLD 9/07....then stolen
93 Honda Civic VX B18C GSR: STOLEN 4-23-06
04 Yamaha R6 ***Stolen 4-18-05***
RabiDIntegrA is offline
Old 03-18-2004, 05:53 PM   #4 (permalink)
Turn the ignition to crank.
Can't get enough of Honda
bruinteg is offline
Old 03-18-2004, 09:26 PM   #5 (permalink)
kiddo118 will become famous soon enough
Instead of doing all that, can I just remove the ECU fuse?
kiddo118 is offline
Old 05-31-2004, 02:37 PM   #6 (permalink)
Car: 2005 STi
greddy102 is a name known to allgreddy102 is a name known to allgreddy102 is a name known to allgreddy102 is a name known to allgreddy102 is a name known to allgreddy102 is a name known to all
what happens when you dont do this step. CAn you damage anything like the ignition module?
greddy102 is offline
Old 06-09-2004, 11:18 AM   #7 (permalink)
kinghawk's Avatar
Car: 1992 BMW 325is
kinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddesskinghawk Rep God/Goddess
Well it would result in a higher than proper presssure reading due to excess fuel build up in the compression chamber
kinghawk is offline
Old 08-16-2004, 06:43 PM   #8 (permalink)
i3lazedx is on a distinguished road
is there anyway to test compression on a motor thats not in the car? hand crank it??
parting out 2 94 civic coupes.. pm if intrested
i3lazedx is offline
Old 08-20-2004, 10:42 AM   #9 (permalink)
SH Virus
Car: '97 Accord EX & '98 F150 4x4 ext cab Lariat
spray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whore
No way that I know of. You can perform a compression leak down test. That'll let you know if you have a bad cylinder or if something isnt seated correctly.
spray004 is offline
Old 01-10-2005, 04:43 PM   #10 (permalink)
2jzSupraGTTE can only hope to improve
help
what numbers are low and high compression. which is better low or high? help meeeee
2jzSupraGTTE is offline
Old 02-02-2005, 07:50 PM   #11 (permalink)
Car: 2007 Fit Sport M/T
Mods: T1R Turbo kit, T25 @ 6psi, 2.5" TBE
explosivpotato is on a distinguished road
compression results
good compression is usually above or around 150 psi, and higher is almost always better, unless the cylenders are mismatched by more than 10 or 20 percent.
Higher psi means that the cylenders are preventing blow by by making a better seal around the side of the cylender.
but be careful, if your results are too high you could have carbon deposits in your cylenders, but this usually provides an uneven result.
1994 Mazda POS -- GONE
2007 Fit Sport MT, T25 @ 6psi
explosivpotato is offline
Old 02-02-2005, 08:39 PM   #12 (permalink)
Depends on engine. Some are pretty low. B18c motors are pretty high. I have seen 250psi in mine and 190's on other high end sport cars. As long as its within specs and not with too much variation between the cylinders. The test is to see if there are huge difference in compression.
female four is offline
Old 01-16-2006, 12:03 AM   #13 (permalink)
quikflip27's Avatar
Car: 1997 civic dx hatch
how many cycles should the engine be turned? cuz it goes up after each one...my auto teacher said 5
-Ivan
quikflip27 is offline
Old 01-16-2006, 12:13 AM   #14 (permalink)
Until the gauge stops climbing.
Old 03-18-2006, 10:39 PM   #15 (permalink)
ek9wannabe's Avatar
Car: 1993 civic dx
Mods: 93 hatch, 1.9 Ls/vtec
ek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sad
not when the valves are opening and closing
cycle the engine once for every cylinder (4 cylinder equals four cranks of the engine)
ALL MOTOR LS/VTEC
192 whp/128 tq
well 200 HP just wasnt cuttin it, goin turbo this time check out my build thread
http://www.superhonda.com/forum/f9/uh-oh-another-build-thread-ls-vtec-turbo-330267/
1990 crx SI zc swap
1993 civic dx NA ls/Vtec
2000 civic ex on boost: sold
ek9wannabe is offline
