» Sponsors
» Sponsors
Register Home Forum Active Topics Gallery Video Sales Mark Forums Read
Old 03-27-2005, 08:56 PM   #1 (permalink)
Cautela's Avatar
Car: '94 Integra Ls/vtec-Turbo, '93 R33 Skyline GTS-25t
Mods: Never enough...
Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?
OBD1 Honda ECU pinouts
These are the pin designations for the OBD1 ECU as well as their wire color and voltage. I always have a hard time finding this information when I need it as I'm sure others do, so here it is
KEY:
(voltage values measured in DC Volts unless otherwise specified)
V = Volts
Wht = White
Blk = Black
Grn = Green
Yel = Yellow
Brn = Brown
Blu = Blue
Org = Orange
KOEO = Key On Engine Off
KOER = Key On Engine Running
A, B, D= Slot. Numbers are read up and down from left to right, not straight across (see diagram at end).
A1-INJ1 INJECTOR#1 Brown, Battery Voltage with KOEO
A2-INJ4 INJECTOR#4 Yellow, Battery Voltage with KOEO
A3-INJ2 INJECTOR#2 Red, Battery Voltage with KOEO
A4-VTS VTEC solenoid GRN/YEL, n/a
A5-INJ3 INJECTOR#3 Blue, Battery Voltage with KOEO
A6-PO2SHTC O2 sensor heating element Org/Wht, Battery Voltage with KOEO
A7-FLR1 fuel pump Grn/BLK, Battery Voltage with KOEO
A8-empty A7 and A8 have the same circurt, so they can be the same
A9-IACV IAC valve Blk/Blu, About 10v KOEO on Warm engine
A10-empty
A11-EGR Control Solenoid Valve (if the ECU has it) Red, n/a
A12-FANC engine coolant temp switch Blu/red, n/a
A13-MIL MIL (check engine light) Blu/wht, n/a
A14-empty
A15-ACC (a/c compressor clutch) Red/Blu, n/a
A16-ALT C alternator Wht/Grn, n/a
A17-IAB IAB Solenoid Pink, n/a
A18-Org/Red, Transmission Control Module (A/T), n/a
A19-White, Intake control solenoid, Battery Voltage with KOEO
A20-PCS EVAP purge control solenoid Red/Grn, n/a
A21-ICM Yel/Grn, Ignition Control Module output signal, About 10V KOEO
A22-Igniter, same as A21
A23-PG1 ground Black, Power ground, less than 1V
A24-PG2 ground same as A23
A25-IGP2 to main relay and to ground Yel/blk, Battery positive from Main relay, Battery Voltage with KOEO
A26-LG1 gound Blk/red, less than 1V
B1-IGP2 to pin A25 Yel/Blk, Battery positive from Main relay, Battery Voltage with KOEO
B2-LG2 ground to shields for CYP & TDC Brown/Blk, <1V
B3-Orange, upshift/downshift comparative input, n/a
B4-Pink, upshift/downshift comparative input, n/a
B5-ACS a/c switch Blu/Blk, a/c input, ~5V with KOEO & A/C off; <1V KOER with A/C & blower on
B6-empty
B7-Light green, Park/Neutral switch (A/T), <1V in Park or Neutral with KOEO; 5V in Park or neutral with KOER; Battery voltage in all other positions
B8-PSPSW PSP switch Red/Green, Power steering oil pressure switch, 0V KOEO; Battery Voltage KOER While slowly turning steering wheel
B9-STARTER SIGNAL starter signal Blue/red, Battery Voltage in the START position (clutch depressed on M/T models)
B10-VSS vehicle speed sensor Orange, Pulses 0-12V while turning the left front wheel
B11-CYP P CYP(#1 piston position) -P Orange, CYP sensor input, n/a
B12-CYP M CYP -M White, CYP sensor signal, n/a
B13-TDC P TDC(top dead ceter) -P Org/Blue, TDC sensor input, n/a
B14-TDC M TDC -M Wht/Blue, TDC sensor signal, n/a
B15-CKP P CKP(crank position) -P Blu/Green, CKP Sensor input, n/a
B16-CKP M CKP -M Blu/yel, CKP Sensor signal, n/a
D1-VBU Back Up Power Wht/Yel, Battery positive From battery through Fuse Box, Battery Voltage at ALL times
D2-BKSW brake switch Grn/wht, Battery voltage at all times
D3-KS Knock Sensor Red/Blue, n/a
D4-SCS service check connector Brown/Wht, ~5V (M/T); ~11V (A/T)
D5-empty
D6-VTM VTEC pressure switch Light Blue, n/a
D7-TXD/RXD (data link connector) Light Green/Red, n/a
D8-empty
D9-ALT F alternator Wht/Red, Alternator Charging Signal, ~4.5V KOEO; Decreases under Electrical load (Headlights & rear defogger on) At warm idle
D10-ELD electric load detector input Grn/Blk, n/a
D11-TPS (throttle position sensor) Signal Red/Blk, ~0.5V KOEO with throttle fully closed; ~4.5V KOEO with throttle fully open
D12-Wht/Blk, EGR Valve Lift sensor, ~1.2V KOEO
D13-ECT (engine coolant temp) sensor input Yel/Blu, ~5V KOEO (varies with temperature)
D14-PHO2S O2 sensor White, heated 02 sensor Signal, 0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes
D15-IAT Intake Air Temperature sensor signal Red/Yel, .05-4.5V KOEO(Varies with temperature)
D16-VREF (no info)
D17-MAP Map Signal Wht/Blu, ~3V KOEO (Varies with Temperature)
D18-Light Green/Blk, Transmission Control Module (A/T Only), n/a
D19-Red/Wht, Reference Voltage, ~5V KOEO
D20-Yel/Wht, Reference Voltage, ~5V KOEO
D21-Blue/Wht, Sensor ground, <1V
D22-Green/Wht, Sensor ground, <1V
"Look out", gaijin with スカイライン
αθεος
Helpful threads: DIY distributor cap/rotor replacement | Got idle problems? CLICK HERE | Honda OBD1 ECU pinouts
Video threads: Stubborn kill | My ls/vtec Turbo vs Si Turbo | Okinawa undergound racing | Skyline+full exhaust+tunnel
Cautela is offline
Old 03-28-2005, 10:04 AM   #2 (permalink)
Cautela's Avatar
No problem. Diagrams coming soon
Edit: diagram is up
αθεος
Cautela is offline
Old 04-13-2005, 07:19 PM   #3 (permalink)
matttewchr is an unknown quantity at this point
i recently changed my obdII to an obdI what the hell did the mechanics switch over, which wires did they chage.
'99 Acura Integra, LS b18b1 JDM swap to b18b.
matttewchr is offline
Old 04-22-2005, 01:03 PM   #4 (permalink)
Car: 95 GSR
Its doubtful they changed any wires. All they did is add an extension onto a wire harness so the new OBD 1 ecu will plug into that.
Check out my old Si-T
uoboarder is offline
Old 05-02-2005, 12:11 AM   #5 (permalink)
Car: 1992 Honda Civic DX Sedan
Mods: Alot!!!
civicrider92 is an unknown quantity at this point
this just helped me out after 2 hours of searching
civicrider92 is offline
Old 11-03-2005, 07:12 PM   #6 (permalink)
spoon ek9 has a little shameless behaviour in the past
Thumbs up hondata
p28 with hondata s200 for SALE IS TUNED FOR JDM TYPE R B18C WITH 193 HP $400 OBO INTERESTED EMAILME@ SPOONHYBRID1@AOL.COM OR (407)9630592
spoon ek9 is offline
Old 11-23-2005, 04:54 PM   #7 (permalink)
vspc2nr is an unknown quantity at this point
KEY:
V = Volts
Wht = White
Blk = Black
Grn = Green
Yel = Yellow
Brn = Brown
Blu = Blue
Org = Orange
A10-empty
A14-empty
B6-empty
D5-empty
D8-empty
D16-VREF (no info)
Would this include the P28 ECU pinouts?? cause i found a site that the color wires were diffrent from yours. Im looking for the signal, ground and 5v wires for my P28 ecu withs a B16a installed.
wrong thread dude. :byye
Why are you in here?
The forum exists for the free exchange of information. It and we are here to help people.
If you aren't here to help people, then maybe you shouldn't be here.
This is not a fraternity, and it's not the Commonwealth Club. There is no initiation. There is no hazing.
Just help, and help without trying to make people feel bad for being new.
George Knighton
vspc2nr is offline
Old 03-21-2006, 04:28 AM   #8 (permalink)
hky
hky is an unknown quantity at this point
does this applies for prelude BB4 ECU? does anyone knows how to disable the 180km/h speed limit on JDM ECU?
hky is offline
Old 04-17-2008, 08:17 PM   #9 (permalink)
Car: 93 Lude Si
Mods: Just tryin to get it goin!
Littlebean357 is on a distinguished road
Help!
Ok, I have a 93 Lude, trying to troubleshoot the EGR system. Got 3 pages into it and it called for a tool to hook up to the ECU which is what is shown on this thread. Where do I get that harness to test the voltage?
Littlebean357 is offline
Old 01-04-2009, 04:36 PM   #10 (permalink)
honnut is on a distinguished road
I put a tec in my 90 si rex i would like to convert the wires for the p28 ecu & distrib myself but can't find info. It's a p28 ecu & distib sohc please help need my drugs back
honnut is offline
Powered by vBulletin®. Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
