Alright so I had a 95 B18b1 swapped into my DA9 and after the swap I noticed that the far bottom left stud that connects the exhaust manifold to the head was missing. All of the other studs are there and the header is on tight to the gasket. Apparently it snapped off during the swap. I was told not to worry about the one stud because it would not really affect anything. I was told that the work it would need trying to fix it by drilling/ re tapping was not really worth it and that having one missing stud was not going to create a leak.
Is this true? I just want some other opinions. Later down the line I plan on going ls/vtec with a B16 head so im not too worried, but I want my car to last untill then with as little problems.
