05-21-2008, 06:30 PM
#1 (permalink)
Car: 2000 civic hatch (b16a)
Mods: skunk2 coilovers, rota slipstreams, integra brakes, jdm b16a, JVTR header, intake, 2.5" exhaust w/ obx twin loop muffler,...,jdm ek9 gauge cluster, shift boot, fog lights,and the list goes on and on...
what do i do???
what do i do if my car has CEL 22 (which is vtec pressure switch) and my engine was made without the switch? im pretty sure i have the right ecu?
05-22-2008, 02:39 PM
#2 (permalink)
need help with this!!!!!!!!!!!!!?????????????
05-22-2008, 03:18 PM
#3 (permalink)
Car: 2004 Mazda Rx8
Mods: Cobb accessport, MM/BHR turbo pushing 9psi, excedy stage 2 clutch, lightweight flywheel, mazdaspeed coilovers, 3" pipe exhaust no cat or muffler
if it was made with CEL it has a switch i dought they would sell it without one... what kind of ECU do you have?
05-22-2008, 03:27 PM
#4 (permalink)
Car: 1989 mustang gt
Mods: nothing notta zilch but i'm working on it
did you do an engine swap because there is no reason for a CEL for something you don't have are you sure you read it right.
05-22-2008, 03:41 PM
#5 (permalink)
Car: 96 hatch
What wire harness are you using? And how did you wire up the V-TEC
05-22-2008, 08:47 PM
#6 (permalink)
i have an obd1 jdm b16a (the 170hp version). it came with a p30 ecu. i used my DX harness with obd converter and ran a wire from the vtec solenoid to my ecu. i was told that some jdm b16s were made without the vtec pressure switch. there is no sign of one ever being there.
05-23-2008, 11:39 AM
#7 (permalink)
Car: 96 hatch
It has to be! There is your problem you have to run some more wire's
05-23-2008, 11:45 AM
#8 (permalink)
i don't know if the b16 has one or not but if it doesnt (you know if he swapped a B16) and he is using an ECU off an engine that did have it that could be causing a problem
05-23-2008, 11:59 AM
#9 (permalink)
Car: 96 hatch
I have the same set up, He is missing the the V-TEC solenoid wire
(pin out 15 on connector C)
05-23-2008, 03:48 PM
#10 (permalink)
what do you mean by "pin out 15 on connector C)"? the vtec solenoid is pin A4 and vtec pressure switch is pin D6? and my ecu is jdm obd1 p30. it dont have a connector C
05-24-2008, 08:27 PM
#11 (permalink)
Car: 96 hatch
Trace the wire from your original harness not the ECU
05-24-2008, 09:55 PM
#12 (permalink)
trace which wire from my original harness? what do i hook it to? my car was originally a DX
05-25-2008, 08:37 AM
#13 (permalink)
Car: 96 hatch
My harness is a DX too, When you plug your jumper wire into the ecu use the wire's coming directly out of the ecu end to trace from there you will need a OBD1 wire diagram
not an OBD2 diagram
05-25-2008, 10:09 AM
#14 (permalink)
i have the diagram but which wire do i trace and what do i hook it to. sorry but you kinda got me confused now lol
05-26-2008, 03:02 AM
#15 (permalink)
Car: 96 hatch
Do you have your knock sensor hooked up?
