Originally Posted by DelSolman03
the head wont because its vtec, which means if you put on a D16 head, you also need the ECU so the vtec will work
so it won't work, and then it will work? which is it? if youre not sure, ill tell you.
it will work if you wanna swap a z6 head on your 15. get a vtec soleniod and different ecu(p28?). this is one of the best upgrades you can get for your d15. close to as many horses as d16z6.
by the way, he can swap on a 16 head without vtec. not all d16 heads are vtec.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
