Old 02-24-2002, 07:04 PM   #1 (permalink)
Flamereka is an unknown quantity at this point
del sol Supercharger
Just wondering if there is anyway to incorporate a Blow Off Valve into a Jackson racing supercharger? Also is there a intercooler for it too? Haven't seen a jackson supercharger motor with a intercooler. I like the Piss, but like the supercharger too, Pus the amount of people having a supercharger is far less then turbo.
so more owwws, and aahhhhs. Heh let me know
Flamereka is offline
Old 02-24-2002, 07:27 PM   #2 (permalink)
NevadaSol is an unknown quantity at this point
Re: del sol Supercharger
I don't think the intake pressurizes the same as a turbo, therefore no need for a blow off valve.
NevadaSol is offline
Old 02-24-2002, 07:38 PM   #3 (permalink)
how about the intecooler? and how much Hp improvement can I expect from a jaclson supercharger ona DOHC del sol? with no mods? except an ignition system.
Old 02-24-2002, 08:12 PM   #4 (permalink)
crappy sol's Avatar
Car: 00 civic si
Mods: pacesetter headers, custom 2.5'' catback, intercooled procharger supercharger, precision 440cc injector, walbro inline 255lbs fuel pump, phearable.net ecu, innovate lc1 wide band o2, ground control with stock shock, energy suspenion bushing master kit, blox rlac and 21mm rear sway bar, asr subframe kit, carbing lower front tie bar, weaponR xbar
crappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these partscrappy sol is infamous around these parts
hey i am in the market for a supercharger too. so is there more then one copany that make supercharger for our sol or are we limited to just jackson racing
crappy sol is offline
Old 02-24-2002, 08:25 PM   #5 (permalink)
Car: student
solar is an unknown quantity at this point
Check out Vortec or Comptech, definatly the Vortec....I know comptech makes one for a S2000, not sure about anything else...
solar is offline
Old 02-24-2002, 09:03 PM   #6 (permalink)
OmegaDelSol is an unknown quantity at this point
Vortec is real good, plus real expensive. I think SC are water cooled.
1996 Del Sol Si
Teamsol member #496
Lots of mods, Too much to list
1990 CRX Si
few things here and there
OmegaDelSol is offline
Old 02-24-2002, 09:34 PM   #7 (permalink)
IndySol is an unknown quantity at this point
Because of how the Jackson Racing Supercharger makes boost it does not create the same kind of heat a Turbocharger at the same 6-9 PSI would. For this reason an Intercooler would not help. Also due to the design of the Roots Style Supercharger incorporating an intercooler would be VERY difficult, if not imposible.
Vortech makes a Centerfugal (Spelling) Supercharger kit which could probibly be made to fit a Del Sol, However having seen one attached to an ITR I would be willing to bet it's not going to be a direct bolt on. Centerfugal Superchargers are basically Belt Driven Turbochargers. They use exactly the same kind of compressor wheel, and housing therefore the Vortech kit does benifit from Intercooling. (It includes an Air to Water Intercooler)
President Team Sol Indy
Team Sol #68
IndySol is offline
Old 02-24-2002, 09:47 PM   #8 (permalink)
With that set up, isn't it more of an "aftercooler"?
Old 02-25-2002, 04:57 AM   #9 (permalink)
GunMetal Member
JDM_SOL is an unknown quantity at this point
Vortech would be great but considering the price I´ll stay with JS or buy a damn turbo
JDM_SOL is offline
Old 02-25-2002, 08:44 AM   #10 (permalink)
Car: Student @ WorWic Community College
CoreyTipton is an unknown quantity at this point
I'm not big on superchargers, but a friend of mine has a Vw Corrado G60 w/ a Lysholm supercharger. I don't know if any of you have heard about the supercharger. It was in the Sport Compact Car issue that featured the Forced Induction. Well anyway it is without doubt the best sounding forced induction sound ever!!! It sounds like a goddamn fire engine. It screams!!! At a car show all he does is start his car and a flock of people crowd around his car. It's incredible. I know that one is made for the d16, at least that's what he told me. And yes there are intercoolers used on Superchargers. My friend with the Corrado uses a water intercooler. It's helps incredibly. Well I'll try to get back w/ his website, let me know if anyone wants it.
Corey
Corey Tipton
'95 Del Sol Si
Not stock.
CoreyTipton is offline
Old 02-25-2002, 09:04 AM   #11 (permalink)
Car: 1993 Honda Civic del Sol S and a gsx-r 1000 and 750 sport bikes
Del La Sol is an unknown quantity at this point
no inter or after cooler for the JRSC but you can get a water injection kit which does a similar job
*2004 Suzuki GSX-R 600(track/race bike)
*2003 Suzuki GSX-R 1000
*2001 Ford Crown Vic P73
*1993 Honda Del Sol S
Del Sol Forum Mod
Motorcycle Forum Mod
Del La Sol is offline
Old 02-25-2002, 10:01 AM   #12 (permalink)
mastalee is an unknown quantity at this point
Vortech too much?
I know that the Vortech Supercharger is expensive $4000-4500. But to get the same performance numbers at 8-9 PSI what is cheaper?
Is it because supercharger max out at a lower PSI than a turbocharger would or is because for the same price you can up the boost on a cheaper turbo kit and get better performance numbers. If this is so then the maintenance may be too high for it.
I know that performance numbers are just numbers, but I was just curious on what everyone meant by getting something better.
Flamereka: I too like that sound the blow off valve makes. I read somewhere that superchargers require blow out valves at higher PSI's, so you may be able to get what you want.
Without a car since Jan 02
Planning on Modified Hybrid Sol
But need to get the car first
Money saved so far for project: $9000 :vpleased:
Money spent so far for parts: -$1250 :laff:
mastalee is offline
Old 02-25-2002, 11:29 AM   #13 (permalink)
Car: 94´del Sol Si
VTEC DEMON is an unknown quantity at this point
I guess there´s no need for a blow off valve, as for intercoolers i haven´t seen a supercharger with those; JR has a "liquid intercooling system" that runs for almost $500 and it doesn´t look like a turbo intercooler.
VTEC DEMON is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
