» Sponsors
» Sponsors
Old 08-01-2008, 09:22 PM   #1 (permalink)
sprayfe is on a distinguished road
Door Striker Ripping from Jamb?
Anyone else have this kind of problem, or better yet know of any solutions?
Basically the door jamb metal has failed and is allow the striker to bend and tear its way out of the door jamb?
Thanks for any and all help,
Rafe
sprayfe is offline
Old 08-04-2008, 10:08 PM   #2 (permalink)
solman's Avatar
Car: 98 integra ls
solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?
never seen that problem before. Is it a wrecked car? any pics?
check me out www.myspace.com/solman94
solman is offline
Old 08-06-2008, 08:37 PM   #3 (permalink)
Car: 93 Red Del Sol si, boosted
Mods: Blox 12k/10k race series Coilovers,Gold 16" drag dr20,d16z6,Skunk2 Cam,223whp 175wtq,Xtd stage 4 6puck unsprung,Tuned on chrome,Garrett t25 on 12psi,"Type r" lip,one piece black housing headlight/foglight all yellow bulbs.spc lower control arms.Skunk2 upper control arms,Skunk2 Lower tie bar, Driver mod
Food Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphereFood Stamp In the rep troposphere
Both my sols have had the rust in that same spot probally will fail sooner or later wich would suck
Food Stamp is offline
Old 08-06-2008, 09:53 PM   #4 (permalink)
Car: 1996 Del Sol S
Mods: stock i just got it
miguel6632 miguel6632 miguel6632 miguel6632 miguel6632 miguel6632 miguel6632 miguel6632 miguel6632 miguel6632 miguel6632
mine too they resanded mine and painted it hopefully ill protect it a little bit more
miguel6632 is offline
Old 08-07-2008, 08:14 AM   #5 (permalink)
solman's Avatar
Car: 98 integra ls
I never saw this problem before. Maybe it from a leaking top
solman is offline
Old 08-07-2008, 08:04 PM   #6 (permalink)
Car: 1995 Del Sol
Mods: Wide body kit, lambo doors, drilled and slotted rotor front and rear, custom door panels, custom sub box with 2 12" Kenwood, custom racing seats, B16A swap, short shifter, DC 4-1 header and a Kaminari front bumper.
mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk mastermind_jk
The only solution I know of is to hit up suicidedoors.com and get a new stricker and lock plate set. The new stricker is about a 1/2" round and the new lock fits the door. Of course this requires welding as you would have to cut out the old lock and stricker. My buddy did this on his s10 when he did suicide doors and they came out clean. This is the only fix I know.
I don't need to get a life, I am a gamer, I have LOTS of LIVES.
mastermind_jk is offline
Old 08-11-2008, 06:39 PM   #7 (permalink)
McSporster is on a distinguished road
Striker/Door Jamb
Mine is loose, too...but, it did have a front end collision a while back and probably pushed the door back pretty hard. It looks as if the spotwelds are broken. ...still functions OK, but likely will get worse if nothing is done. Does anyone know if there's any way to get access to the rear (inside) of that area? Mc
McSporster is offline
Old 08-11-2008, 08:15 PM   #8 (permalink)
Car: 1995 Del Sol
With out cutting from the outside? The black panel below the speaker panel has a a hole behine it but I dont know how much access you'll get.
Old 08-12-2008, 05:34 AM   #9 (permalink)
Door Striker...
Thanks. I'll dig into it and post any useable info. Mc
Old 08-13-2008, 07:22 PM   #10 (permalink)
Door Striker...
Pulled the adjustable striker off today, ground off the paint and surface rust to find very thin metal with cracks. This was about ready to come apart! We were able to weld up the cracks and, then, cut/weld in place a 1/16" steel plate approx. 2.5" X 5" on the outside as a reinforcement. ...still have to do a little bondo work on the edges and paint, but it looks good, will be hardly noticeable and should last longer than the car (...or, me). ...now, I noticed that the other side has a couple of small cracks around one of the spot welds, so I'll tackle that next. This is apparently a weak point for this neat little car. Mc
Old 08-19-2008, 05:16 PM   #11 (permalink)
nevermnd is on a distinguished road
I'm having the same issue on the driver's side of a '96 I just bought. Do you have any pictures of the final result of your fix you could share McSporster ? I am thinking of going a similar route.
nevermnd is offline
Old 08-19-2008, 05:33 PM   #12 (permalink)
...door jamb
...may take a few days, but I'll try to get a photo or two for you. It seems to me to be the only lasting solution. Frankly, I'm surprised at just how little metal there is there with no real reinforcement -- a cost cutting design flaw IMOH. Mc
Old 08-20-2008, 05:20 AM   #13 (permalink)
Thanks Mc. Particularly what I am wondering is if you meant that you removed the striker from plate and then reattached it on top of your new mounting plate, or if you left it in place and instead made a cut out for the striker simply making a supporting plate that goes around it... Is there anything holding it the OEM striker plate to the frame behind there ? Or is it just those couple of spot welds ? It does seem like a strangely weak way to put together a structural point on the body, esp considering the metal even on the side panels seems thicker than right there in the jamb....
nevermnd is offline
Old 08-20-2008, 06:21 AM   #14 (permalink)
...door jamb
I removed the striker (2 large screws) and lightly ground the area...actually discovered that there had been some welding of cracks there before, and that a couple had reoccured. I ground the surface rust off, welded the cracks again and then cut the steel plate approx. 2" X 5" with holes for the mounting screws large enough so that the adjustment movement could still be made in all directions. Then, welded the plate on with spots around the circumference and rosettes at six places to ensure that it's well connected. As the plate is only approx. 1/16" thick I believe that some good work with bondo and painting will make it virtually disappear and I'm thinking that it will be a permanent fix. ...hope that makes sense? Let me know if I can clarify (...and, sorry for no photo yet -- I'm much better at auto repair than I am at "computer stuff"). Mc
Old 08-21-2008, 03:57 AM   #15 (permalink)
That's quite alright. I removed the striker plates and sanded down the sides yesterday; Aside from the spot welds, the support plate for the striker behind the outside body appears to be free floating ? So a word of caution to anyone just pulling the screws out-- if far gone enough the plate might just fall in all together. Aside from your mention I noticed at the salvage yard the other day the same issue on a couple of other del sol's there. I'm a little surprised that Honda never issued some sort of recall for this sort of thing as it does seem like a weak spot and something of a safety issue. Thanks for the info Mc.
nevermnd is offline
