Old 06-07-2008, 08:49 PM   #1 (permalink)
Yoyocafe is on a distinguished road
Help! Del Sol won't start
I've been lurking here for a few weeks, but this is the first time I've posted. I've bought a 93 Del Sol S, 1.5 D15b7. Tonight while I was driving it the car died. I played with it and got it to start again, but then it died again.
I had the car towed home and started to look into it. The engine has no spark. All it does it crank, but no fire. The funny thing is, when I turn the car off, if I do it while it is still turning the engine fires for a split second then it stops because I turned it off. I've checked for spark while doing that and I had some. It made me think the ignition switch was bad, so I checked it according to the Haynes manual. The switch tested good.
Is there another relay or solenoid that would cause this? I checked the coil and the cap and rotor and that's all good.
Yoyocafe is offline
Old 06-07-2008, 11:43 PM   #2 (permalink)
nbboy7's Avatar
Car: 93 Del Sol SI
Mods: Come and find out
nbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to donbboy7 Rep God/Goddess with nothing better to do
It the main relay or fuel pump
nbboy7 is offline
Old 06-08-2008, 06:57 AM   #3 (permalink)
Car: 89crx
yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?
Check all your grounds also the one by the thermostat housing
Originally Posted by Transparent View Post
i left a $0.35 tip on a $30.00 bill the other week. that cunt deserved every penny of it
Originally Posted by got-vtec?
Would it be safe to go about 180-190 mph on the street in a lightened crx.
yellowrexsi is offline
Old 06-08-2008, 09:41 AM   #4 (permalink)
Michael Helmke's Avatar
Car: 1995 Del Sol
Mods: 17"x 7.5" Rims, Nitto Neogen Tires, Energy suspension bushings (engine, suspension and trans) B&M Racing shifter, Antenna block of plate,
Michael Helmke is a jewel in the roughMichael Helmke is a jewel in the roughMichael Helmke is a jewel in the roughMichael Helmke is a jewel in the rough
try hitting the main realy it might catch.
Fuel pump maybe to blame also i had an accord do the same thing. to me
Built from the Ground Up
Michael Helmke is offline
Old 06-08-2008, 05:40 PM   #5 (permalink)
Main Relay
I had to order a main relay, nobody had it in stock. I don't think it is a fuel pump problem, When I turn the key on, I can hear the pump start, and after cranking the engine for a while the garage smells pretty gassy. I've checked for spark and I still don't seem to have any while the engine is cranking. I pulled the ignition switch apart to check the contacts. Cleaned them up but I still get the came results. Does the main relay control the spark too?
Yoyocafe is offline
Old 06-09-2008, 08:46 PM   #6 (permalink)
nbboy7's Avatar
Car: 93 Del Sol SI
try changing the dizzy
nbboy7 is offline
Old 06-10-2008, 03:57 AM   #7 (permalink)
I found the problem, it was a bad Ignition Control Module. Once I replaced that, the car fired right up. Thanks, for all your help and comments.
Yoyocafe is offline
Old 06-10-2008, 11:29 AM   #8 (permalink)
nbboy7's Avatar
Car: 93 Del Sol SI
glad to see you fixed the problem
nbboy7 is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
