My Radio Resets Every Time I Start My Car - Honda Forum : Honda and Acura Car Forums
Ľ Wheel & Tire Center
Go Back   Honda Forum : Honda and Acura Car Forums > Honda - Vehicles > Honda Vehicle Models > Del Sol Forum
Old 06-27-2009, 05:57 PM   #1 (permalink)
morganhinthorne is on a distinguished road
i lose all of my eq settings and radio channels.
it s a sony xplode
someone told me that it may be the fuse, that if i replace it that it will solve the problem
has anyone had this problem before?
i could use some help
email:
hinthorneh@yahoo.com
morganhinthorne is offline
Old 06-27-2009, 06:17 PM   #2 (permalink)
Ninju's Avatar
Car: 1992 honda del sol SIR-Transtop
Mods: OBX spark wires,weapon-r intake,exedy clutch disc,tenrai cat back exhaust
Ninju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sadNinju is sad...just sad
it s a sony xplode
email:
i had the same problem before.it's not the use.if the fuse was blown the radio wouldn't turn on at all.the problem is due to weak battery.change your battery and you will be fine!
Ninju is offline
Old 06-27-2009, 06:35 PM   #3 (permalink)
91EGGURA's Avatar
Location: OKC, Home of the World's Biggest Fucking Idiots
Car: 2008 Civic Si SEDAN
Mods: CAI, performance springs and struts, front camber kit, rear adj upper control arms
91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?91EGGURA you're still here?
or could be grounding issue to as well. if it's not gounded it will get power when power is thrown at it but will completely shut off when power is taken away causing reset. am i right on that?my issues with radio is not my stations but just my setting will go back to factory. it saves my settings as user settings but i shouldn't have to choose user settings just because i put a cd in after listening to the radio
I Am The Almighty Thread Killer
91EGGURA is offline
Old 06-28-2009, 05:40 AM   #4 (permalink)
Olde School Ricer
Car: 89crx
if the back-up fuse (7.5 amp), is blown it will do that
fuse is under the hood.
edit, also if you don't have the memory hooked up on the deck
yellowrexsi is offline
Old 06-29-2009, 02:11 AM   #5 (permalink)
SuperHonda Premium Member
93DelSolProjekt's Avatar
Car: A Bike for now.
Mods: Dayton spinners.
93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy93DelSolProjekt needs rep therapy
thats prolly what it is. Check the ground wie and see if its secure, or even still connected. either that, or sell the sony headunit and buy a better one.
Bitch, I'm From Cleveland!!!
And yes, I'm JUGGALO, if you got a problem with it you can
FUKOOF
93DelSolProjekt is offline
Old 06-29-2009, 03:09 AM   #6 (permalink)
Ninju's Avatar
CHECK the battery like i said before.the car may start like the battery has no problem,but thats not true.anyway write the results here
Ninju is offline
Old 06-29-2009, 03:50 AM   #7 (permalink)
cudaeh's Avatar
Car: y2k grocery getter
Mods: little bit of this and that. lots of suspension bits on order
cudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problemcudaeh has a Rep problem
did you just install the radio? or is this one that has been working properly and then just stopped?
you could have mixed up the switchable 12v with the constant 12v... ive done that plenty of times.
will the back up fuse (7.5a under the hood) cause little to no power on the constant feed and cause the clock not to work?
(sorry donít mean to jack your thread)
I installed my radio the other day and not thinking i started cutting wires bunches at a time. i must have shorted the consent feed because when i checked the voltage at the radio harness the switchable was reading 12v and the constant was only reading 0.3v. I also noticed the digital clock stopped working.
all the fuses under the dash were just fine. but i didnít know there was such thing as a backup fuse under the hood?
would that be my issue?
Ant got nuddin to say to nobody.... so go away! NOW!!!
cudaeh is offline
Old 06-29-2009, 05:27 AM   #8 (permalink)
Olde School Ricer
Car: 89crx
I'm not sure on that. Check the fuse and see, it's labeled as back-up, located under the hood
Old 06-29-2009, 06:15 AM   #9 (permalink)
Ninju's Avatar
i have a transtop and i know exactly what happens with that back up fuse.if he just installed the radio you are right he might mixed up the switchable 12v with the constant 12v.if the back up fuse is blown THE RADIO WILL NOT TURN ON AT ALL,SAME GOES WITH THE CLOCK IN THE GAUGES,AND SAME GOES FOR THE TRANSTOP MECHANISM.if you don't believe remove that fuse and check for your selves.no need to read if it's the backup fuse.that fuse is BROWN and is the only one in the hood with 7,5 Amper.as for the ground wire,i don't think that it can cause that problem.if the radio has no ground connected it won't work.+ i had the same problem and the BATTERY was causing it.the car was starting and ranning just fine but when we measure the voltage on the battery we found that when we try to start the engine the voltage was dropping more than usual and that was causing that RESET of the radio.Thanks
Ninju is offline
Old 06-29-2009, 06:28 AM   #10 (permalink)
cudaeh's Avatar
sweeet, now i know what to check when i get to the parkinglot this afternoon
sooo your saying a cell in the battery might have gone dead? (his issue not mine)
i suppose thats easy enough, take it to your local big chain auto supplyer and have them test the battery for you...
cudaeh is offline
Old 06-29-2009, 06:33 AM   #11 (permalink)
mattliston's Avatar
most likely not a battery issue if the car starts fine and the radio plays fine. the memory wire on the cd player's harness is most likely the cuprit
All about the single cam
Originally Posted by My Caramel Chocolate Lover View Post
mattliston is offline
Old 06-29-2009, 01:21 PM   #12 (permalink)
ihasadelslo08's Avatar
Car: 90 Probe GT
Mods: i does has boosts!!!
ihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a lifeihasadelslo08 You need a life
I had the same problem, your deck has a yellow 12v wire which is, like a few people have said, the constant power/memory wire for your deck. This wire is supposed to go to your positive battery terminal which is what gives it the constant power. If it's not hooked up then you will have the same problem everytime you shut off the car. Good luck, hope this helped
ihasadelslo08 is offline
Old 06-30-2009, 04:40 AM   #13 (permalink)
cudaeh's Avatar
which if i remember correctly from my wireing it shoud be hooked up to the white wire with the blue stripe..
BTW
the backup fuse under the hood was totally what my problem was!
i never knew such a fuse exsisted.
cudaeh is offline
Old 06-30-2009, 05:12 AM   #14 (permalink)
Olde School Ricer
Car: 89crx
BTW
FYI
To reset check engine lights, just pull the back-up fuse
Another little secret for you
Old 06-30-2009, 09:03 AM   #15 (permalink)
cudaeh's Avatar
FYI
sweeeet
cudaeh is offline
