It's not even that the emissions are 'restricted' so to speak, it's just that there are more sensors watching more things that require more work to bypass, and the air/fuel map is more complex and efficient.
OBD2 isn't worse for your car than OBD1. If it was, it never would have made it to the streets. It's just more efficient, and more precise, so it's harder to tune to get more power out of it, because it's specifications are so in tune with each other.
OBD1 is easy because it's a relatively simple ratio of air to fuel to spark to RPM to vehicle speed. OBD2 factors all that differently and calculates it more exact. I would stick with an OBD2 motor for it's newness, and jump it to OBD1 for the ability to tune it at will.
And to answer your initial question, both OBD1 and OBD2 redline at the same actual 8200 redline, but the gauges will display different depending on the year/make/model of Civic/del Sol with a B16.
The 200 RPM won't make much difference anyhow, as you should be shifting before 8000 to have an efficient run regardless of redline. The only reason to up it or worry about it is built engines with superior valve-train, bottom-end, and transaxle components that can withstand the pressures and rotations of that many RPMs.
