But even if you do raise your redline, it will not change where your engine makes peak power unless your ECU is remapped for it. Running a stock ECU will give you the same power at the same points and you will just be running the car out of air.
'97 GBP Del Sol Si
Weapon R intake
Dual Exhaust w/2.25 in pipes
SOLD!!!!!!! to the highest bidder.
Mods: pacesetter headers, custom 2.5'' catback, intercooled procharger supercharger, precision 440cc injector, walbro inline 255lbs fuel pump, phearable.net ecu, innovate lc1 wide band o2, ground control with stock shock, energy suspenion bushing master kit, blox rlac and 21mm rear sway bar, asr subframe kit, carbing lower front tie bar, weaponR xbar
hey i got the mini me set up i need the extra rpm to make max power and redlineing at 6500 is not helping me any good cause if i can take it to atleast 7800 i'll make more power cause of vtecsince i got a si head i need the extra rpm to make more power from the head since it was made to make 125 hp at 7200 rpm
