Old 05-22-2008, 04:48 PM   #1 (permalink)
Ninju's Avatar
Ninju is on a distinguished road
when vtec kicks rpm's jumb up until 9 rpm or more!
Am a proud owner of a del sol sir.lately i had some problems with it.my rpm's gone crazy,my car was swiching off while i was driving,and there were a lot of stall problems.i had some problems like that before and when i changed the distributor coil everything was fine until now.so i desided to change the whole distributor.now everything works fine except one thing.when vtec kicks in my rpm's go crazy!it jumbs from 6-7 rpm to 9-9,5.when i change gear it goes to the right rpm like 5 and when vtec kicks the same shit is happening.any idea what might be?thanks
Ninju is offline
Old 05-22-2008, 05:29 PM   #2 (permalink)
Car: 89crx
yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?yellowrexsi you're still here?
any aftermarket add ons (msd ignition) (super afc)
Check your connection at your distributor plug, might be slightly loose
Originally Posted by Transparent View Post
i left a $0.35 tip on a $30.00 bill the other week. that cunt deserved every penny of it
Originally Posted by got-vtec?
Would it be safe to go about 180-190 mph on the street in a lightened crx.
yellowrexsi is offline
Old 05-22-2008, 05:44 PM   #3 (permalink)
Ninju's Avatar
the whole distributor is aftermarket but brand new.i recently put a new set of spark wires (obx).i will check this in a few hours.hope that's the problem...
Ninju is offline
Old 05-22-2008, 05:48 PM   #4 (permalink)
Car: 89crx
factory aftermarket, or msd
I don't think its the spark plug wires
But the plug that connects the distributor to the engine harness (the one you unplugged to install the new distributor)
sorry for the confusion
Old 05-22-2008, 05:55 PM   #5 (permalink)
Ninju's Avatar
i hope is that simple.i apriciate your help.but why hat happens only when the vtec kicks?
Ninju is offline
Old 05-22-2008, 06:02 PM   #6 (permalink)
Car: 89crx
Not sure, but the tach signal comes from the distributor (no other place), so I would start there
Also check your grounds.............there should be one on the valve cover, and one by the tranny. Honda's act funny when they aren't grounded good.
Wiring problems suck, so I feel your pain. Most the time they are solved by something extremely simple that was overlooked
Old 05-22-2008, 06:13 PM   #7 (permalink)
Ninju's Avatar
i will check the things you say and i will let you know.yeah wiring problems are a big pain man..and most time the problem is untraceable,but i only hope is something simple.i will let you know.thanks again
Ninju is offline
Old 05-22-2008, 07:53 PM   #8 (permalink)
coop3422's Avatar
Car: 1999 Honda Civic Si
Mods: AEM cai, catback exhaust, custom Kenwood/Hertz stereo
coop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a lifecoop3422 You need a life
i second wiring problems suck, my right rear turn signal dussnt work, and the bulb and socket are both fine :S. Hope you find your problem
Sourcing a turbo kit for my d16y8
Originally Posted by riceboy89 View Post
im having a bad day. unfortunately for you.
coop3422 is offline
Old 05-23-2008, 05:57 AM   #9 (permalink)
Car: 95 del sol vtec
Mods: h22 swap, supercharged, cat back exaust, stainless steel ,headers, 3" lowered with coil overs, 17" wheels
parish parish parish parish parish parish parish parish parish parish parish
Was yr clutch in when u reached vtec rpm? If it was then rpm jump is normal.It will bounce for some seconds and come back to normal
other cars owned: 2003 mercedes slk
97 honda odyssey
Sold
whats next?
2009 corolla?
2008 civic?
2008 Fit?
2008 Yaris?
parish is offline
Old 05-23-2008, 12:20 PM   #10 (permalink)
Ninju's Avatar
no the clutch wasn't in.problem solved today!the problem came from my NEW distributor.i opened the distributor cap,and there are 3 wires connected with fuses.so these fuses were very loose,i tighten them and everything works fine!Non ORIGINAL accesories (like my distributor) SUCK!thank for your help guys
Ninju is offline
Old 05-23-2008, 01:42 PM   #11 (permalink)
Car: 89crx
glad to here
once again, a simple issue
Old 05-23-2008, 03:51 PM   #12 (permalink)
coop3422's Avatar
good to hear it was an easy fix
coop3422 is offline
Old 05-23-2008, 04:55 PM   #13 (permalink)
Ninju's Avatar
yeah so simple! :P but could take ages to solve the problem..
Ninju is offline
Old 05-23-2008, 08:06 PM   #14 (permalink)
solman's Avatar
Car: 99 gt vert
solman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problemsolman has a Rep problem
You cant tell us you have an SIR then not post pics of it.
check me out www.myspace.com/solman94
solman is offline
Old 05-23-2008, 08:07 PM   #15 (permalink)
solman's Avatar
Car: 99 gt vert
BTW, glad it was an easy fix
solman is offline
