05-17-2005, 01:18 PM
#1 (permalink)
Dark Wind
Car: 07 HRP SI Sedan
Mods: nada
Compression Vs. Torque
Ok I have a question... Does compression ratio have a large effect on torque? And if so is it higher compression higher torque or is it vice versa?
we are not defined by words or images. Rather by our actions and our footprint left on this world. A.K.A. :
F.I.L.A
05-17-2005, 01:22 PM
#2 (permalink)
Lifeless Ninja
Car: 92 prelude
Mods: jdm h22
cant be vice versa DAT has been proven many times, for example most good nissan motors(fourbangers) have mad torque not very high compression--at least not like a honda....but im thinking the other way around works more often than not in that way especially from my own experience, i got cams and pistons swapped and the torque went crzy compared to how it was---this a was on a jspec h22
pistons were 10.5-1 went to 11-1 and type s cams...big huge ginourmous difference in torqaue
2000 ek coupe. black. stock.
myspace
05-17-2005, 02:04 PM
#3 (permalink)
torque has to do with bore, and stroke. hondas have small bore and small stroke, hence the high end power gains, with a longer stroke you will have more torque, but less rpm. thats one of the reasone all the muscle cars rev out at like 4k.
huge bore+huge stroke = huge torque
small bore+small stroke=high rpm power
silence is golden
but duct tape is silver
05-17-2005, 03:04 PM
#4 (permalink)
Dark Wind
Mods: nada
So how would you go about changing your bore and stroke
F.I.L.A
05-17-2005, 09:27 PM
#5 (permalink)
SH Virus
Car: pair of pumas
Big bore + small stroke = high rpm power
You can think of your rods and crank acting like a lever. The further they can be moved, the more work they can do (like a longer lever). The problem with a long stroke and higher RPMs has to do with piston speed. Increasing the stroke will increase piston speed, and that will increase friction, which will cause the engine to operate inefficiently. This isn't a problem if the car isn't driven in it's high RPM range often, but if a car is driven at high RPMs frequently, this can lead to excessive wear and stresses, possibly even failure.
"Racing is a matter of spirit not strength."
On some models the AC controls are located on the door panels. Temperature is selected by how far you rotate the crank and the fan is operated by the long skinny pedal to the far right. The further you depress this pedal, the higher the air flow.
05-17-2005, 11:19 PM
#6 (permalink)
yea, i know that, but i was just talking about hondas in general, with the small bore+stroke combo
silence is golden
05-17-2005, 11:23 PM
#7 (permalink)
SH Virus
Car: pair of pumas
hondas = small everything
05-17-2005, 11:26 PM
#8 (permalink)
except exhaust tips and wings
silence is golden
05-17-2005, 11:37 PM
#9 (permalink)
SH Virus
Car: pair of pumas
...and egos, don't forget that
05-18-2005, 06:13 AM
#10 (permalink)
Lifeless Ninja
Car: 92 prelude
Mods: jdm h22
hey, now, chill.........
good thread, good info, now its awhole lot clearer for me.
myspace
05-18-2005, 06:23 AM
#11 (permalink)
SH Virus
Car: '97 Accord EX & '98 F150 4x4 ext cab Lariat
Yes it does. Compression has an affect on both torque and hp. Simply put, the more squeeze you have, the more go you 'll have. Two given engines with the same bore x stroke, but w/ two diff Compression ratios. The higher compression ratio engine will have more torque and hp.
big bore/small bore + small stroke = high rpm
big bore/small bore + big stroke = low rpm
12 National Championships, 21 SEC Championships, 54 bowl appearances, 30 bowl wins
ROLL TIDE
05-18-2005, 08:37 AM
#12 (permalink)
Dark Wind
Mods: nada
Ok so if a higher compression helps torque how the hell do you raise your comperssion ratio?
F.I.L.A
05-18-2005, 08:39 AM
#13 (permalink)
DUH! B16, H22 and VTEC, y0!
05-18-2005, 08:51 AM
#14 (permalink)
SH Virus
Increase cylinder volume and/or decrease combustion chamber volume.
ROLL TIDE
