Old 04-13-2004, 08:16 AM   #1 (permalink)
mike_sho's Avatar
Car: 93 Honda Prelude VTEC
Honda Tech Tips.
Lets compile a list of Honda Tips.
List any sort of tip for your car: What you do , what you use , clean , how to drive , anything. Any sort of tip that you know about and do, your favorite / most effective one that you want to pass along for others to know.
mike_sho is offline
Old 04-13-2004, 08:21 AM   #2 (permalink)
Civic Ex Chick
Posts: n/a
LOL. That's kind of a hard question.
I guess here's mine. I drilled a hole through my back bumper so that the water will drain out and stop that ever famous honda quarter panel rust. I also wash my car religiously because of the salt here in the winter.
Old 04-13-2004, 08:27 AM   #3 (permalink)
mike_sho's Avatar
A digital tire pressure gauge is your friend. Make sure your tires are at equal pressures. At least left to right. Front and rear you might want to mess with different pressures to get certain effects. But I tend to leave it all the same for standard driving.
Some use more pressure in the rear for more straightaway speed / acceleration , but this makes you loose rear grip traction , so its more safe to run the rear tire the same as the fronts on the street. If you goto the 1/4 mile track its ok to try , then relieve pressure before driving home.
-- Also some use lower tire pressures in the rear for more rear grip if it tends to slide in corners.
mike_sho is offline
Old 04-13-2004, 05:01 PM   #4 (permalink)
Dark Samurai
BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?
Cool things if you store your car/drive it only once or twice
a month:
A battery-minder: http://www.batterymart.com/batteryminder.php.
This bitch is worth it's weight in gold.
A Craftsman air compresser: http://www.sears.com/sr/javasr/produ...id=00915054000. I didn't think
this one would work too well, but it's pretty awesome.
An "Accutire" digital tire gauge. I got mine at Target.
Nothing special, just a lot easier to read.
BlueBallz is offline
Old 04-13-2004, 06:22 PM   #5 (permalink)
mike_sho's Avatar
Thats exactly what I got , it lights up too. Its somewhat hard to get the pressure with it....but it works well once its sealed.
I noticed once I level my tires with the digital gauge....the car drives much better.
mike_sho is offline
Old 04-14-2004, 01:01 AM   #6 (permalink)
Car: 88 teg rs
Mods: so many things to do..
rex'er is just really nicerex'er is just really nicerex'er is just really nicerex'er is just really nicerex'er is just really nice
two things.. digital tire guage from walmart that fits on keychain and is as big as one of those little sqeeze led lights. pimp shit.
second.. drilled holes in bottom of crx tails to end spare tire swimming pool when it rained. oh yeah.. no more sloshy sloshy around the corners. pimp shit indeed!
rex'er is offline
Old 04-14-2004, 06:41 AM   #7 (permalink)
Dark Samurai
My tip on cleaning windows: on the outside, (since I
consider my Sol's paint part of my flesh ), spray the
Windex, (or whatever you use), on the rag and then clean.
On the inside, clean the windows first, (I use Windex
'Powerized'; it's a foaming aerosol, like 'back in the day'
before they banned CFC's). Don't worry too much about
hitting the plastic parts, just clean them later with some
Meguier's. Also, Meguier's Endurance IS "the shit" for
your tires, IMO.
It's pretty obvious, and probably doesn't do any harm,
but if I saw a bum rushing at me at a stoplight with
some window cleaner and a rag, I'd definately freak.
I did it once, after I waxed the car, and it leaves
major streaks/blemishes. Probably just screws with
the wax, I guess.
Old 04-14-2004, 10:31 AM   #8 (permalink)
Cypher Wave
Transparent's Avatar
Car: I dont own a car
Mods: fuck off
your tires, IMO.
the wax, I guess.
just a note on cleaning the inside of the window for those who dont know. If the windows are tinted dont use anything with amonia in it. That will eventually turn your tints purple
Werd bitch
Phantoms like a mother fucker
Transparent is offline
Old 04-15-2004, 08:06 AM   #9 (permalink)
Dark Samurai
That's a good one. My's Sol's not tinted, but the Nissan
is; I'll have to remember that.
Old 04-15-2004, 11:15 AM   #10 (permalink)
90Si's Avatar
Car: GTF away thief
Mods: Porsche air filter
90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?
i bet thats why my tint in my car is purple (scrapped it all off though)
i was about to give a tech tip but i forgot when i hit the reply button...
90Si is offline
Old 04-18-2004, 07:17 AM   #11 (permalink)
mls
Dark Samurai
mls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to behold
& when you clean the rear glass, wipe horizontally to avoid damaging the defroster strips.
mls is offline
Old 04-18-2004, 07:23 AM   #12 (permalink)
BBs99's Avatar
Car: 1993 Acoord SE
BBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant futureBBs99 has a brilliant future
silicone around the fresh air vent behind the cover in the trunk. i started to get water laying in there and this solved that problem.
BBs99 is offline
Old 04-18-2004, 10:17 AM   #13 (permalink)
Car: 96 Honda Prelude Si - Soon to be 2006 Civic Si
Mods: ADR 17 Wheels, Tokico shocks, H&R Springs, DC Sports Intake.
Middle Finger U is on a distinguished road
I've never even used a tire guage Well maybe for my mom, but I've never had a problem with tire pressure
Middle Finger U is offline
Old 04-18-2004, 10:29 AM   #14 (permalink)
mike_sho's Avatar
Little do you know what your missing , yeah a car can go out and drive and feel fine. But go out with perfectly matched tires , its a nice difference.
mike_sho is offline
Old 04-18-2004, 10:31 AM   #15 (permalink)
mike_sho's Avatar
Also yeah the window tint is very true. Never use ammonia. Ammonia solutions are whats used to remove tint. Also if you decide to remove your own tint. If you do the rear , never use a razor blade or anywhere near your defroster anything harsh that can break it....
mike_sho is offline
