vtec in it's stock form and turbo =
here's why: vtec is an NA trick that helps the engine breathe in high rpm's. in the b16, it opens the valves higher and longer. long enough to where both the intake and exhaust valves are opened at the same time (called overlap). overlap causes the air and fuel to be sucked in and out of the combustion chamber a lot faster. turbo's don't like overlap because you're trying to keep all the boost inside the combustion chamber. w/ the overlap from an NA tuned camshaft (ie, the stock b-series cam), you will get some of your boost to leak, along with some of the gasoline that you'll need to safely buffer any predetonation.
you could remedy this by getting some turbo camshafts, but i don't know any companies that are mass producing them just yet. which means a grip of money on custom camshafts.
