Absolutely! But no matter what, putting a stage 3 turbo on your car will put more strain on the engine by increasing the dynamic compression ratio. That will increase the temperatures in the cylinder and start melting the piston, valves and everything. So I guess it would be a good idea to replace those parts with more durable ones.
So, here is what I am asking. When you tune for performance, you start out with filters, intake, exhaust, etc... Even these simple upgrades will have more strain on the engine. So are there also some kind of guidelines that when you install some certain performance parts, you should also consider replacing others with more durable ones? Like the turbo example, you may consider new pistons that can handle higher temperatures.
The reason that I am asking is that, I know a bit about cars, basics at least. However, I know there is a lot of stuff out there to be learned. Obviously with the cost of this stuff, I don't want to learn through trial and error. So I'm looking for some guidelines.
Thank you.
