Hi, I have a 1995 honda accord LX, I'm curious to know if anyone knows a website or can explain to me the easiest route to take when replacing a few wheel studs up front.
You can't do it by yourself, you need a press (or whatever its called).....You can do it the cheap way, and just bend the heat sheild out of the way, but it's up to you if you want to do it the right way, or save some money.
__________________ Arctic Blue Pearl RSX Type S
i-VTEC do you? Check out my ride
AEM CAI - JDM Type R Intake Manifold - Hondata IMG - JDM Type R Cams - DC Sports SS Race Header - Greddy Evo II - Hondata K-pro (Untuned) - Progress Coil Overs - Progress Front Sway Bar - Progress Rear Sway Bar - JDM Type R Headlights - JDM Type R Valve Cover - VIS OEM Carbon Fiber Hood
u can do it ur self its pretty simple. on my 93 accord all i had to do is take the tire off and there is a round plate that is bolted to the rotor with two or four bolts remove that and hammer the studs out and put new ones in. install is reverse....
Mods: 5% Tint, WeatherFlectors, Altezza TYC Tail Lights, Steeda Short Throw, Steeda Oval Emblems, Euro Clear Corners, Hoen H10 Fog Lights, MBRP 2 1/2 exhaust, AEM CAI, Jumbo Ram-Air Shield (SVT Snorkle), AutoMeter Dual A-Pillar Pod, Air/Fuel Ratio and Volt
LOL I think a slide hammer will tear up the threads on the way in. I have banged them out useing a hammer then to install the new ones slide them in from the rear and put a couple washers on then the nut and tighten till it pulls all the way through. It's not hard at all just take your time
2003 Infra Red Svt 3 Door # 3389 of 3985
5% Tint, WeatherFlectors, Euro Spec Tail Lights, Steeda Short Throw, Steeda Oval Emblems, Cervini's Mach 5 Hood, Euro Clear Corners, Hoen H10 Fog Lights, Redline Underbody Neon Kit, Eibach Sportlines, MBRP 2 1/2 exhaust, FC Throttle Body, Screamin Demon and Livewires Setup, FC UDP, AEM CAI, Jumbo Ram-Air Shield (SVT Snorkle) AutoMeter Dual A-Pillar Pod, Air/Fuel Ratio and Voltmeter Lunar Series Gauges.
