'89 Civic Si hatch - CEL code #5, dies after 20 seconds
'89 Honda Civic Si hatch - 1.6L D16A6
Start it up, it boggs really bad sometimes cutting out all the way. If I give it some gas for a second it will run healthy for about 20 seconds, then slowly cutting out. Having some problems with fuel delivery? Would be my guess...
Anyway, the idle has been jumping around for the past couple weeks. Tried numerous things, still running like crap. I was getting CEL code #3, then #5...
#3 being "MAP sensor or circuit elecrtical fault"
#5 being "MAP sensor mechanical fault"
Not completely sure of the difference...
Hit the salvage yards, found a couple different MAP's. Tried them and now Im just getting CEL code #5. (Trying to avoid spending $230 on brand new MAP sensor alone) I just replaced the spark plugs with some basic single prong platinums...the ones that I pullled out were 4 prong. Definately not a good choice of plug for NA A6.
Fuel pump?
Bad gas?
Injectors?
TPS sensor?
Speed sensor?
Im lost, and almost fed up with messing with it. Help me out here.
Thank you in advance.
Drive like you HAVE some sense, even if you dont.
Choose 2>>>>>FAST, RELIABLE, CHEAP
"Friends dont let friends......." wait just a darn minute, friends dont care what friends drive.
1999 Honda Civic Si - DD
1989 Honda Civic Si Hatch - PROject
1988 Honda CRX DX - PROject #2
