Old 05-18-2006, 08:26 PM   #1 (permalink)
loudaudio1 is an unknown quantity at this point
99 Civic DX is leaning!!!
Does anyone else have this problem? My friend who has a 96 DX does the same thing. Both are leaning on the driver side. Neither one of them have been wrecked. Both cars were leaning before any aftermarket suspension was installed. My car is sitting about a half inch lower on the driver side and so is his. I cant figure it out.
I have replaced the springs, struts, and the top hats. Everything looks like its normal, nothing is bent or sagging.
The thing that I cant understand is that even before the new suspension went on it leaned like this. Its the same thing in both the front and the back.
Anyone know what it might be?
Thanks,
Paul
loudaudio1 is offline
Old 05-18-2006, 08:32 PM   #2 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
naturally the lower control arm bushings (front and rear) are going to wear more quickly on the driver side.
my car does it as well......actualy most all civics i've seen that have lowering springs or stock suspension lean some. the only ones that don't are the ones on coilovers or coilsleeves.
98civcEK is offline
Old 05-19-2006, 01:45 PM   #3 (permalink)
Car: 1998 Prelude
Ludebreathinez is an unknown quantity at this point
My 99 GSR did the same. They all come from the factory like that. I really don't know the reason, but there has to be one. Maybe the factory figures in passengers and weight variances and one sided needed to me a slight higher or lower than the other.
Ludebreathinez is offline
Old 05-19-2006, 02:40 PM   #4 (permalink)
Car: '89 Civic DX hatchback
legacyo13 is on a distinguished road
Is it possible the US uses the same specs from the Japanese Honda's. Maybe the driver side in Japan sits higher for the drivers weight. Maybe they didn't notice it in the US. Makes sense if you ask me. It'd all work out if we sat on the right side of the car. Have your friend sit in the passenger seat, then measure it.
legacyo13 is offline
Old 05-19-2006, 02:43 PM   #5 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
honestly my front is fine, its the rear that you can see the difference.
98civcEK is offline
Old 05-19-2006, 03:01 PM   #6 (permalink)
Hmmm, I dont know. Its bothering me though, I think its something to the point of a bushing or something but the bad part about that is that I have new lower control arms in the rear and new bushings in the front. This shit is wierd.
Old 05-19-2006, 03:05 PM   #7 (permalink)
Car: 93 prelude si vtec
Mods: jdm h22, header, high flow cat, cat back exhaust, cai, stage 1 exceddy clutch with 8 pound flywheel, gauges in a pod, system...much more to come
johnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhile
sounds like some kind of conspiracy to me
i always thought my 4th gen lude kinda leaned toward the driverside. i thought it was alwyas uneven ground.
93 prelude, jdm h22a, lots of mods great car---FOR SALE
http://www.superhonda.com/forum/showthread.php?t=317981
2005 subaru sti---the beast
johnlude85 is offline
Old 05-19-2006, 05:14 PM   #8 (permalink)
Cypher Wave
.TheCriMson[K20]'s Avatar
Car: 97 Civic / 06 RSX-S
Mods: lotz
.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!
my civic never leaned.. even on stock 9yr old shocks, springs, and bushings.
.TheCriMson[K20] is offline
Old 05-19-2006, 09:09 PM   #9 (permalink)
SH Virus
Jo060's Avatar
Mods: fuggin' your mom.
Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?
word. No gangsta-leanin' here
MEMORIZE THIS NOOBS
Fast+Cheap=Not Reliable
Cheap+Reliable=Not Fast
Fast+Reliable=Not Cheap
4 Doors are the best!!
Jo060 is offline
Old 05-20-2006, 06:18 AM   #10 (permalink)
civic_x_95's Avatar
Car: Former ED6 and EJ1 owner. I roll a Jeep for now... I like em topless and dirty!
civic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a life
Yeah... never had that problem... havent really noticed it on others either...
... get a bushing kit, maybe you have some weak ones or blown ones. also check yourt tires, might be low on pressure??
Unless your 88-91 CIvic/CRX is RHD and the 4&5 letters in your VIN are "EF", you DONT have a EF.
civic_x_95 is offline
