Old 04-23-2008, 01:16 PM   #1 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
Mods: front-gsr strut and tenzo r strut bar, Lower rear-spoon strut, tokico suspension, and rear disc brake
Cheerioeg6 is on a distinguished road
tech wrench adjusting D16z6 compression
I just finished on my mini me swap and my head was giving me a low compression test # (all four was 150 PSI)...i was wondering how do you adjust the compression so that it will reach 180 or 170 psi ......thanks
Cheerioeg6 is offline
Old 04-23-2008, 08:14 PM   #2 (permalink)
Zinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sad
what head did you put on it?
Zinc is offline
Old 04-23-2008, 11:10 PM   #3 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
d16z6 head was installed on a b15b7 block
Old 04-24-2008, 07:32 PM   #4 (permalink)
Sorry my bad, you should have higher compression than the d16z6. Maybe you're timing belt alignment if off.
Zinc is offline
Old 04-24-2008, 07:46 PM   #5 (permalink)
Maybe your head is warped and the gasket is leaking? Did you check for warpeage?
Zinc is offline
Old 04-24-2008, 09:49 PM   #6 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
haven't recheck it yet but my car idols between 2 and 1 rpm....got a new d16z6 head gasket, belt...yep...what kind of compression did you guys get from yours...
Old 04-24-2008, 10:11 PM   #7 (permalink)
You can't really adjust the compression with a sohc, that's the problem, the overlap is built into the cam.
With that setup I've heard of them testing at like 180psi per cylinder. I've never done a mini-me myself. If you're getting low compression, then either your timing is off or you have a compression leak. Or valves are staying open, maybe. Did you rebuild the head or get it from a working engine?
Zinc is offline
