Old 05-13-2006, 07:50 PM   #1 (permalink)
bob12345's Avatar
Car: 2000 FGP Type SH Prelude
Mods: stuff
bob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a lifebob12345 You need a life
Which blocks can I use?
My room mate has a 97 Civic EX auto (d16y8). She was driving home today and the motor started spraying oil out of the block onto the exhaust manifold. My first question is, what would cause the block to crack?
Second is, which blocks out there can I use to replace this one. Of course the ideal situation would be to swap the entire motor/trans out for a better one, but the funds just aren't there. We might end up doing a long block, but probably no more than that.
Thanks for the help!
bob12345 is offline
Old 05-13-2006, 08:45 PM   #2 (permalink)
Car: 2000 civic hx
Mods: full tsudo catback exhaust,cai,,17inch black rims with polished lip, Eibach "sportline" lowering springs, type r headlights, rockford fosgate "power" 6.5's & 6/9's, pioneer deck, t2 15" Subwoofer powered by fosgate T15004 amplifier, dc sports 4-2-1 headers, no cat
blackouthx is on a distinguished road
any d series. do you hava a cai by any chance or low on oil
2000 HX
DC 4-2-1 headers
AEM CAI
2.25 cat back
Eibach Sportlines
SKunk 2 front camber
front upper strut bar
blackouthx is offline
Old 05-14-2006, 12:02 AM   #3 (permalink)
bob12345's Avatar
Mods: stuff
She has a short ram, and the oil level was good til it spilled out all over the side of the I-10.
bob12345 is offline
Old 05-14-2006, 02:02 PM   #4 (permalink)
Car: 2000 civic hx
the reason i asked is because i had a cold air and one day i sucked up water causing it to throw a rod through the block. low oil can cause you to throw a rod also.
2000 HX
DC 4-2-1 headers
AEM CAI
2.25 cat back
Eibach Sportlines
Old 05-14-2006, 02:50 PM   #5 (permalink)
bob12345's Avatar
Mods: stuff
I'm startin to think it has a thrown rod too, whatever the cause may have been. Now the search for a new block...
bob12345 is offline
Old 05-14-2006, 07:14 PM   #6 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
yup any block will do, but i'd stay with the y8 if possible.
98civcEK is offline
Old 05-14-2006, 08:19 PM   #7 (permalink)
bob12345's Avatar
Mods: stuff
Unfortunately that's the one d series block I'm having a hard time finding...
I've seen plenty of d15, z6, zc, y7 (which I think is the same as the z6 but I'm not sure) and even a few d17, but no y8.
Since her car is vtec, would there be any problems using a non-vtec block? I know H23 vtec requires a huge amount of work to make functional, but not so sure on the d series engines...
Maybe somebody in here can point me to a y8 short/long block, or even has one laying around they wanna part with....
bob12345 is offline
Old 05-14-2006, 08:22 PM   #8 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
it was just a recomendation. the y7 block will do just fine. you only have to remove the oil jet from the center coolant passage (just like on a mini-me) and you good to go.
98civcEK is offline
Old 05-14-2006, 08:26 PM   #9 (permalink)
bob12345's Avatar
Mods: stuff
Alright, I'll keep an eye out for that one...I'd like to at least keep it a d16 if possible. Don't wanna go to a d15 very bad, d17 might be kinda cool if it worked, but they're more money
bob12345 is offline
Old 05-15-2006, 07:38 AM   #10 (permalink)
IISaiNtII's Avatar
any 92-00 d-block will work, but there will be some quirks to work out. like getting a block that has no knock sensor and having to use an ecu that requires one.
also, if emissions are strict where you live, it will be limited to newer blocks than the car only..
-Proverbs 16:31
- Martina Navratilova
IISaiNtII is offline
Old 05-15-2006, 08:27 AM   #11 (permalink)
Car: 1992 Honda Civic DX Sedan
Slipjack has much to be proud ofSlipjack has much to be proud ofSlipjack has much to be proud ofSlipjack has much to be proud ofSlipjack has much to be proud ofSlipjack has much to be proud ofSlipjack has much to be proud ofSlipjack has much to be proud of
You should be able to get a y7 block for cheap. Don't pay more than $300 for it (plus shipping if it's being shipped) because NOBODY buys those motors unless it's either an emergency (like your case) or it's all they can afford and their old motor is on the way out.
That's what I'd do in your position.
- Hoosier Daddy
1992 Civic DX sedan, project car | 4 Doors are the best!!
DIYs: 5th Gen Civic EX Tach Installation
Slipjack is offline
Old 05-15-2006, 10:27 AM   #12 (permalink)
96civichx is an unknown quantity at this point
i wuz a half quart low in my 90 accord and racied a motor cycle on the freeway doing 130 and it started clicking i pulled over checked the oil and notting wuz the opend the oil port and it wuz smoking like snoop dogg lol did no put it throw the block it still starts up and clicks real bad but bought a 92 accord ex and swaped a head that wuz fucked up on that car. mayb your oil pump wuz cluged
96civichx is offline
Old 05-15-2006, 10:59 AM   #13 (permalink)
civic_x_95's Avatar
Car: Former ED6 and EJ1 owner. I roll a Jeep for now... I like em topless and dirty!
civic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a life
English please... and use sentences.
Unless your 88-91 CIvic/CRX is RHD and the 4&5 letters in your VIN are "EF", you DONT have a EF.
civic_x_95 is offline
Old 05-15-2006, 12:09 PM   #14 (permalink)
bob12345's Avatar
Mods: stuff
well the insurance company seems convinced from her description of the damage that the block cracking was related to her rear ending somebody recently. I'm pretty sure it's not, but it's their call. If they decide the engine is cause of the wreck then the car will be totalled.
We'll see what they say in a couple days...
bob12345 is offline
Old 05-15-2006, 02:47 PM   #15 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
Best to stick with a 96-00 block that way you are guaranteed to get a 1.6L block (some 92-95 were 1.5L), and you don't have to deal with different wiring issues that will arise by trying to use a 92-95 block in a 96-00 chassis. Best to get a d16y8/ex block, but a d16y7/dx/lx block will work as well. If going d16y7 then you will essentially end up with a mini-me.
kommon_sense is offline
