Mods: Black headlights, CAI, 3" tailpipe...lots of HP there!!!
brakes conversion
i bought a used set of 15" rims off a 99 SI to put on my 93 EX. i seemed to have not researched enough because i just found the lug pattern on the SI rims is larger than the pattern on the 93 hub. is it possible to convert the 93 brake and hub assembly, front and back, over to a 99 SI assembly? please help! thank you.
Bigger, Badder, and Better
That's exactly what I was thinking, but I've never actually worked on a 5th gen.
the only 4 lug honda that isnt 4x100 (iirc) is some type r integra that was 4x114.3. all the 4 lug civics are 4x100.
to the op, did you actually try to put the wheels on?
i did try to put them on, then i did a little research and found out they are accord rims, which are nearly identical to SI rims. they`re useless now, cause im not spending the money and time to convert the entire brake and hub assembly to an accord setup.
