Old 12-31-2006, 08:49 PM   #1 (permalink)
civic_x_95's Avatar
Car: Former ED6 and EJ1 owner. I roll a Jeep for now... I like em topless and dirty!
civic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a life
Cant get axles out, need motor out!
So... has anyone pulled an engine without removing the axles? I cant get the ball joints to release on either side, so I was thinking I would just try and leave the tranny in the car and pull the motor, I've left tranny's in place before but I didn't have the axles still in place... can it be done?
Unless your 88-91 CIvic/CRX is RHD and the 4&5 letters in your VIN are "EF", you DONT have a EF.
civic_x_95 is offline
Old 12-31-2006, 09:33 PM   #2 (permalink)
Dark Wind
iLLeFFeKt CiViC's Avatar
Car: 93 civic dx
have you tried using a ball joint or tie rod puller??
1991 Galant VR-4
1989 Camry -daily beater
1993 Civic dx-sold
1991 Eclipse gsx-sold
iLLeFFeKt CiViC is offline
Old 01-01-2007, 01:02 AM   #3 (permalink)
Car: 2003 Accord Ex Coupe
Mods: Huge wing, couple of kanooter valves and oh yes the whipple valve too! Super V-tak, gay stickers, parts that don't work, some mats like Strongman ftl
lowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problemlowcivic66 has a Rep problem
Try using a pry bar to pop the axles out of the tranny, it has always worked for me.
Quote: Originally Posted by rnstein69
um, 0 to 60 in 9 seconds? my grandmother can do the moonwalk and still beat you off the line..
http://en.wikipedia.org/wiki/Honda_Civic
lowcivic66 is offline
Old 01-08-2007, 09:17 AM   #4 (permalink)
allspoolin4 has a spectacular aura aboutallspoolin4 has a spectacular aura aboutallspoolin4 has a spectacular aura about
drop the subframe take out the one motor mount and trans mount then take off everything connected to the fire wall 4 bolts i think, good luck
allspoolin4 is offline
Old 01-10-2007, 12:31 PM   #5 (permalink)
icedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a lifeicedveins You need a life
Do they have something online like a manual that shows you how to pull an engine? All I know is that you start with the Shift-linkage.
icedveins is offline
Old 01-10-2007, 05:07 PM   #6 (permalink)
ek9wannabe's Avatar
Car: 1993 civic dx
Mods: 93 hatch, 1.9 Ls/vtec
ek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sad
use a pickle fork and an impact on the ball joints.
ALL MOTOR LS/VTEC
192 whp/128 tq
well 200 HP just wasnt cuttin it, goin turbo this time check out my build thread
http://www.superhonda.com/forum/showthread.php?t=330267
1990 crx SI zc swap
1993 civic dx NA ls/Vtec
2000 civic ex on boost: sold
ek9wannabe is offline
Old 01-12-2007, 09:17 AM   #7 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
I put a jack under the control arm, and jack it up. Then place a bar in the little space between the control arm and the knuckle. Then slowly lower the jack. The pressure from the shock/spring pushing down causes the ball joint to pop out without damaging the ball joint or the boot.
kommon_sense is offline
Old 01-12-2007, 12:49 PM   #8 (permalink)
civic_x_95's Avatar
yeah I have done that... but couldnt this time since the only jack I have was occupied... I got them finally... my pickle fork just kept spreading open so my buddy brought his HUGE fuggin pickle fork and we beat the shit piss outta it and they finally popped out... luckily didnt rip the boots.
Old 01-24-2007, 08:27 PM   #9 (permalink)
Car: 95 Acura Integra
**JDMTEG** is on a distinguished road
pickle fork and hammer always work for me...
**JDMTEG** is offline
Old 01-26-2007, 11:04 AM   #10 (permalink)
Administrator
Johnny Tran's Avatar
Car: 2005 Acura RSX-S
Mods: OEM Body Kit
thats the trick i used when i did my clutch. It worked like a damn charm!
08 Infiniti G37S
05 NBP RSX-S -Traded in
2000 EBP Si
STOLEN 11-21-04
Team OG
Johnny Tran is offline
Old 02-01-2007, 04:01 PM   #11 (permalink)
klungemonger's Avatar
Car: 98 Civic DX hatch
You don't even need to take the ball joints out, although it makes it easier. And then only the top one which is way easier to get loose. Just get the nut off and whack the top of the knuckle a few times real good with a hammer and it will jump right out.
klungemonger is offline
Old 02-01-2007, 05:18 PM   #12 (permalink)
Car: 2000 Civic EX
Mods: I/H/E JDM d15b vtec LOADS of suspension
speedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep troposphere
for balljoints I like to do this, jack the car up and put it on stands both sides. loosen the balljoint nut, jack the car up by the hub untill the car just barely comes off the stand.(2000+lbs of pressure) then take a hammer and smack the lower a-arm, usualy just takes 1 or two well placed wacks.
I think pickleforks are gay never used them. all you need is a bigger hammer .
good luck with the swap man! Im in the middle of one as well along with a full suspension rebuild hahaha.
MY VOUCHERS:
-Paypal:danijel_danicic@hotmail.com
-Ebay:dado03235
Originally Posted by riceboy89
nice setup man
(speedjunky01)your mom is so jdm!
CIVIC PRESSURE PLATE *CHEAP*
speedjunky01 is offline
Old 02-02-2007, 11:34 PM   #13 (permalink)
HondatechAV6's Avatar
Car: 2000 Accord Lx V6
i don't understand why you need the axles out to pull the motor. i leave the trans in unless it's getting replaced also.
i shock the ball joint out of the lower control arm. you have to have good aim and strike the lower control arm where the ball joint goes into it. you have to know how to hit it though, otherwise you'll just start denting the arm. hit it like you properly hit with a sledge hammer, if you know how. it takes 2-3 hits and doesn't leave a mark.
I'm just a nice guy.
HondatechAV6 is offline
Old 02-03-2007, 02:06 AM   #14 (permalink)
civic_x_95's Avatar
Ok seriously people read dates of posts and check to see if things have been solved before replying... I keep getting replies about this and I got them a couple days after I posted this... but thanks for trying to help non-the-less.
As far as why am I pulling the trans... it's a whole hella lot easier to pull everything versus trying to get the trans and shaft lined up and together when in the car... not only that, but original plan was to swap to a 5spd out of a 5th gen, but that plan has changed due to not having the cable-hydro bracket yet. Now I'm looking for a SI trans for it instead.
Old 02-03-2007, 03:38 AM   #15 (permalink)
Car: 1988 civic (J)
Mods: B20b B16 head CTR cams type R intake ITR header MSD ignition password whale penis intake spoon PR3 and VTEC controller Gea
xxxdoc is infamous around these partsxxxdoc is infamous around these parts
Just cut them as a matter of fact cut the axels and the mounts with a sawzall it will fall right out !
xxxdoc is offline
