Old 07-05-2008, 11:37 AM   #1 (permalink)
VTEC_Civic97's Avatar
Car: 97 Civic EX
Mods: AEM SRI, Apexi Dunk Cat Back, Stage 2 Clutch, Lightweight Flywheel, 9.3mm spark plug wires/plugs, SI tailights, Dropzone Struts, Sprint Springs, "Mugen" front upper strut bar
VTEC_Civic97 is on a distinguished road
Exclamation CIVIC MINI-ME HELP ASAP
Have a little problem doin my mini-me (long story dont ask why i'm doin one):
ok the block (d15b7) and head (d16y8) are all bolted up but my question is since the block is obd1 can i still use my old ECU (with no place for the crank position sensor or the knock sensor on new setup) or will i need an obd1 ecu...PLEASE HELP ASAP THANKS
VTEC =
VTEC_Civic97 is offline
Old 07-05-2008, 12:30 PM   #2 (permalink)
Car: 97 Civic EX
anybody?
VTEC =
Old 07-05-2008, 01:28 PM   #3 (permalink)
Joewill2848's Avatar
Car: 89 crx si
Mods: 17" wheels cat back exaust black halo headlights black corner lights clear marker lights blck rcing seats 4 point harnesses spoon sports steering wheel blacked out windows strut tower bar skunk2 shift nob complete energy suspension bushing kit energy suspension mtr mnts white face gauges body kit fresh red paint battery discnect swtch lambodoors
Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848
u will need a p28 ecu to do the swap correctly i hope you also pulled the tab out of the block to let oil flow for the vtec setup it should be on the block right up from the distributor where vtec hooks up
on my 14th car and i doubt the madness stops here
Joewill2848 is offline
Old 07-05-2008, 02:16 PM   #4 (permalink)
Premium Member
ILIKEDINGLEBERRIES
ltlblkcvc's Avatar
Car: 99 Civic
ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?
wrong you can use an obd2 ecu to run an obd1 block i'm doing it now. you do not need to use the p28 just to use your setup. trace down the wires for the cps and the one for the dizzy and jump the wires. as long as the ecu reads that the crank and dizzy sensors are in sync then it will run fine. and I wouldn't even worry about the knock sensor I've been running my engine for quite a while without one
Originally Posted by WVU97GS-R View Post
Originally Posted by HonduhDave
By no means do I think I'm a genius
Originally Posted by Snoopy
ltlblkcvc is online now
Old 07-05-2008, 02:19 PM   #5 (permalink)
Premium Member
ILIKEDINGLEBERRIES
ltlblkcvc's Avatar
Car: 99 Civic
i'm not on my comp but i will look for the diagram you need. the info is in a thread somewhere on this site. i posted in it quite some time ago
Old 07-05-2008, 03:11 PM   #6 (permalink)
Premium Member
ILIKEDINGLEBERRIES
ltlblkcvc's Avatar
Car: 99 Civic
found it the search function works great. did a search for cps and distributor and looked until I found a few I posted in. so heres the site
.:FFS TechNet : CKF Bypass Trick :.
heres the thread
somthing wrong with my swap
I promise if you do this correctly it will run fine I have been running my engine with this for about 6 or 7 months with no problems. also read the thread above as I added some other info, that might be useful, that I found out when swapping my motor in
Old 07-06-2008, 07:22 AM   #7 (permalink)
Car: 97 Civic EX
thanks alot i will def. try this because i took my car out last night and it ran like shit lol
VTEC =
» Site Navigation
» Home
 > FAQ
» Other Sites
