Bigger, Badder, and Better
i think it'll be fine.. but a guy who knows alot about v8's and shit says it'll be to much compresson...
so his word is good to me.. but he dont really know bout 4 cylenders
old school muscle, 10:1 is high. there are plenty of stock hondas that run over 10:1 b18c5, h22's, k20's all run 11:1, if its good enough for oem, its good enough for a built engine.
12:1 is about the limit i would run on stock compression. too far after that and you have to pull the timing so much it negates the added power/torque from the increased c/r
Running a higher compression ratio requires a much more precise tune. You can probably run 12:1 on 93 just fine but you need to make sure that it's tuned by someone who knows what they're doing and that you keep it tuned. 11:1 is still high but it's by no means impossible. Again just make sure that the motor has been tuned and that your tune is checked regularly so your motor is happy.
