i check lubrikation oil limiter, the oil is not mixed with cooling. and the cooling water is in normal limti, its not goeing down, just oil is gone at the time
about head gasket it was first idea, what i want to change, but then i take a look in lubrication oil then its going down, i try to ask someone who can help, maybe its not only head gasket
so, thanks a lot for your time and for your help
ill try to change head gasket and let you know, about engine work with new gasket
