Old 04-13-2008, 09:14 AM   #1 (permalink)
Mariuxs's Avatar
Mariuxs is on a distinguished road
Wink d16y7 engine problems
blowing smokes form exhaust, and eating lubricating oil ... were can be problem? thanx for any help
Mariuxs is offline
Old 04-14-2008, 11:09 AM   #2 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
what color smoke? Is it white or blue?
How fast are you burning oil? 1 quart/liter per week? etc?
kommon_sense is offline
Old 04-18-2008, 08:22 AM   #3 (permalink)
Mariuxs's Avatar
smokes are light grey color, and lubrication oil burning half liter on the week, but engine works great, starts very good, the RPM is not jumping in empty gears.. sometihng wrong with engine, one problem is the head gasket, couse the cooling pipe is a little bit blowed, but engine cooling temp is normal after longer drive on the streets
Mariuxs is offline
Old 04-18-2008, 08:43 AM   #4 (permalink)
A bad headgasket will cause smoking. Fix the headgasket and go from there.
Old 04-18-2008, 11:18 AM   #5 (permalink)
Mariuxs's Avatar
but why gones lubrication oil ? can it e pistons rings or something else?
Mariuxs is offline
Old 04-18-2008, 10:04 PM   #6 (permalink)
blown headgasket can cause oil/coolant to mix. Also when you remove the head to change the gasket, you will be able to look at the cylinders to see if you notice anything abnormal.
Old 04-19-2008, 01:18 AM   #7 (permalink)
Mariuxs's Avatar
i check lubrikation oil limiter, the oil is not mixed with cooling. and the cooling water is in normal limti, its not goeing down, just oil is gone at the time about head gasket it was first idea, what i want to change, but then i take a look in lubrication oil then its going down, i try to ask someone who can help, maybe its not only head gasket so, thanks a lot for your time and for your help ill try to change head gasket and let you know, about engine work with new gasket
Mariuxs is offline
Old 04-19-2008, 06:03 PM   #8 (permalink)
i misunderstood you. It sounded like you were saying you *knew* that you had a bad headgasket.
If you aren't losing coolant, then the headgasket is probably ok. I would recommend checking for oil leaks around the oil pan gasket, and front/rear main seals. Next do a compression test to make sure the rings are good.
You should also pull and inspect the plugs to see any signs of fouling. Possible that you also have a leaky valve seal.
Old 04-20-2008, 02:45 AM   #9 (permalink)
Mariuxs's Avatar
at first i make a diagnostics test, ant people say that it probably gasket problem, couse at first time were was just smokes, but after longer drive i saw that oil is gone so, it can be not only gasket, i will chek better around engine maybe it can be oil filter leaking or something else, but than i buy a car, the oil limiter was over maximum, so i was cheated buy seller... and thats why i have this problem. but everything is fixing so need just a little bit time to found were the problem is
Mariuxs is offline
