I believe the 1-5 gearing is the same for all of them but the hatch has a 3.76 f/d and the coupe/sedan has 4.06 or some such thing. Here's a simple formula for you to figure out the speeds yourself:
RPM @ redline / final drive ratio / gear ratio = RPM at wheels
(Tire diameter / 12) X 3.14 = Tire circumference, in linear ft.
1 Mile / Tire circumference = Wheel revolutions per mile
(60 / wheel revolutions) X RPM @ wheels = top speed
Here's an illustration to break it down. Say you have a GSR that redlines at 8000rpm. You have tires that are 24" diameter. The tranny is a 4.4 f/d and first gear is 3.23...
8000 engine rpm / 4.4 fd / 3.23 = 563 wheel rpm
(24" dia / 12) X 3.14 = 6.28 ft
5280 ft (1 mile) / 6.28 = 840.76
(60 / 840.76) X 563 = 40.17mph
Once you have some of that data all figured out all you need to do is just change the gear ratio (third number in the first formula) and recalculate. OR...go to this link and just add in your numbers and it will spit stuff out. I wrote this because while a web calculator is the easy way, you should still understand the principles of how/why you get the numbers. Just put your 1-5 ratios one at a time into the "overdrive gear" box after filling the other stuff in.
http://www.mysportscar.com/tools/topspeed.htm
