Im thinking that the timing belt was put on to tight. I bought it from a dealer and his mechanic put the timing belt on. that was at 108k, when i start the car when its cold it squeaks loud. ill probaly end up bringing it in to $honda
I can smell antifreeze when it warms up and can find no leaks anywhere, thinking the water pump might be leaking? but started smelling after installing s2 intake manifold?
the belts all have tensioners on them that have a specific torque spec that put them at the right tension. but if the dealer replaced the timing belt and the belts squeak its there fault.
well if coolant spilled out like it is expected to, when you start up for a bit there will be a coolant smell.
it started to smell after i installe a s2 intake manifold, something has to be leaking, im just going to bring it to the dealer and get it fixed, im sick of screwing around with the drive belts. thanks
