The stock sensor is good to 11 psi. However - anything above atmospheric ( ZERO BOOST) it will trigger a check light and throw the car into limp mode. They sell one way check valves called 'missing links' to keep the boost from getting to the map sensor but allow the sensor to see vaccuum. They are cheap - work well and on a budget are your only option. You don't need to change your map sensor unless you want more boost and are tuning using the map. (hondata) Hope this helps.
HENRY
