Originally Posted by JDMCivic00Ex
thanks alot guys.. yeah thats what confused me mine dont say vtec so i wasnt sure. and to add.. i pulled off the ground today to reset the check light to see if it would come back on and it didn't so far.. i went to get gas and came back home.. no CEL. but i have reset the light before and it did come back on.. and the idle is still pretty high in park around 1500 =\ idk if the coolant helped any or not maybe thats why theres no CEL. but i still experience the backfire in the exhaust and i noticed a difference in excelation from 0 to about 20 it takes forever. could that be because my cat is bad? the rattle is pretty bad and i know it prob wont even pass emissions. i've just been waiting to fix the idle problem and CEL.
anyone got any other ideas? thanks
Ive been having a similar problem...
from what i can see the idle is just that way, its a bit high in neutral but once in gear drops...
if the rattling is comming from under your car then its your cat.
my problems was a p0420. so i replaced the cat. CEL came back on, so i replace the o2 sensor that goes into cat. CEL came back on, so i took off the header and sprayed inside with degreaser took off the cat, sprayed that with degreaser, and took a steel wire brush to my exhaust ports. and wipped both o2s off clean, and then used presurized air to blast any loose dirt out. I am about to change my ECT and coolant too, and if that dont work then im going to do the o2 non fouler trick or put my stock cat back on as i have degreased the inside of that tooo...
your problem sounds like a vac leak to me... check the cruise control line to the back of the intake manifold. had the same prob as you when it was disconnected, when i tried to use ac and/or cruise i would bog and almost stall. unless the rattling noise is coming from the engine bay then it could your ac compressor
