The block will bolt up and work, mechanically.
You'll notice there is nearly no wires on the block itself...in fact on most blocks the only thing that gets wired up is the oil pressure sender, except on OBD2 motors like your HX the oil pump houses the crank fluctuation sensor. So, you will basically need to swap the OBD2 HX pump, sensor, and timing belt gear onto the Z6 block to make it function properly with your HX ecu.
