my friend is swapping a y7 in his hatch, which currently has a d16a6 block with a vtec head, not sure exactly which head it is though. Will this distributor work with the y7? if not, is there a way to make it work?
the d16a6 actually has a stronger crank girdle than the y7
__________________ Myspace.com
Porn should only be a brief guide into what the
standard should be when you look for a girl, to trigger a reaction of self-improvement and become a Master Pimp, so others can either follow the example or look with envy when you have a porn-quality woman in your arm, regardless of economic status quo.
You can use the A6 (obd0) distributor, it bolts perfectly to the Y7 (obd2)without modifications.
Not the same case for a Z6 (obd1) for which the A6 (obd0) distributor does not bolt up.
he is running a y7 ecu. is there an obd1 version of the y7? i didnt think there was but he said its an obd1 y7 ecu
if it is obd1 than he should use a obd1 ecu p06 , p28
I hope the link helps
