when i accelerate it feels like my engine is missing...the problem goes away if i turn my car off then back on...but only for a little bit. Sometimes it will run fine for a couple days and then it will act up again...need help .......maybe ecu bad??
Be more specific with the problem you are having. You said that it feels as if your engine is missing. If your engine was missing your car wouldn't run. So, is your car not running? More details, please.
__________________ MEMORIZE THIS NOOBS Fast+Cheap=Not Reliable
Cheap+Reliable=Not Fast
Fast+Reliable=Not Cheap 4 Doors are the best!!
when i say missing i mean on a cylinder. like one cylinder isnt firing. but it only happens intermittently. its fine today so far...but later it might start acting up so its not a vacuum leak or anything like that....it has a full tune up...new fuel filter.took injectors out and cleaned them and they all work fine...im thinking ecu is possibly messed up..but i dont know thats why im asking for some input
If it had misfired then the CEL would have come on.
