hey do somebody can tell me what modifications i have to do if i put a ls vtec engine(bl8 block & b16 head) in my civic ex. I will probably buy this engine but i need to know wat kinds of modifications i have to do in my ex 95 ppl had tell me that i can use my p28 in this engine its this true? Do i have to cut or remove something or the engine will fit perfectly??
Mods: Currently Stripped completely....Fuckin Crooks.
thx ryo
you dont need to cut weld or modify NOTHING as long as you have your b series mounts, halfshaft, axles and trans you are set. of course you will need a generator, and a started for B series. but to answer your question NO modifications to your engine bay is requred to do a b seires swap. and yes your p28 will work.
a chipped p28, the stock won't have the right base maps for the b16 head.
