Failed emission test
hi ppl , im asking you for some help , because i went to the anual inspection , inspection that we are obrigated to do , here in Portugal ...
I´ve swappped an D16Z6 , into my civic K , and all went right till the emission test , that failed with a high value ,passing by far the limit by law ...
my KAT and oxygen sensor is ok , already saw the electric instalation for defects or bad conections on oxygen sensor when i did the swap , and with this i have a theory that i need your knowledge to confirm...
the Z6 OEM honda exhaust manifold , have the spot of the oxygen sensor into that point were the primaries join , into a common chamber , were the sensor can read all the 4 cylinders , the aftermarket exhaust manifold that i have instaled the sensor goes into ONE of the primaries only , so i can deduce that the sensor is reading only 1/4 of the mixture , and the ECU goes to compensate that with more fuel and incrise the emission ...causing my car to fail the emission test , can it be?
